42mpg today
Old May 28, 2016 | 09:49 PM
Kburgad's Avatar
Kburgad
Default 42mpg today
Went for a ride today with the missoula harley owners group and bikers against bullies awarness group. First time out after competing both cruising tune and richer tune. 12.8 to 13.2 left the richer tune in it. Wasn't planning on going last min thing. After doing some guesswork math at the pump was around 42 mpg 76 miles could only get 1.8 in the tank. I was stoked. Before the tuner had stage 1 ecm downloader got 35 at most if I was under 80 mph. Now got Andrews 26 cams off with auto tune and bassani road rage.
Old May 29, 2016 | 12:24 AM
FLS103's Avatar
FLS103
I have done a lot of work to my bike. Increased compression, cams, headwork, 54mm Throttlebody, 4.9 injectors. The bike has 118 HP and 118 torque and it averages 42 to 43 mpg unless I ride it really hard. As a Stage 2 with 92 HP it averaged 35 to 36 mpg. Don't make sense but I like it
Old May 29, 2016 | 06:45 AM
Bluraven's Avatar
Bluraven
I'm only at a stage 1 with a V&H Fuel Pak and on back road rides @ 55-60 mph I generally get around 40-42 mpg.
Around town I get pretty much 35-38 mpg.
On the open highway at 75 mph it's 36-38 mpg.
Of course the wind plays a huge role and at 75 mph I have gotten 40+ mpg with the wind at my back and 35- mpg with the wind in my face.
Also, I'm generally not hard on the throttle either.
Old May 29, 2016 | 10:55 AM
Kburgad's Avatar
Kburgad
I've got an 04 so originally no o2 sensors. Better tuning now with widebands. Stage 1 download too rich by a lot I guess. Just need to build it more I guess
Old May 29, 2016 | 06:42 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Same here, cam, tuner, dyno, stage 2. It's that federal emission regulation on the stock setup holding it back. Scoot runs and the mpg is a tad above 40 unless I'm runnin it hard.
Old May 29, 2016 | 11:39 PM
Kburgad's Avatar
Kburgad
I run my **** hard all the time the last 25 miles of the run we were up at 95 most of it. The first 15 we were up there too.
Old May 30, 2016 | 01:30 PM
oct1949's Avatar
oct1949
same here,, since I added the 26's and had the SERT tweaked, back in 09,, I always get between 41-44 (putting around)- 44-47 (on the road) ... Always a bit lower when I have to use Ethanol gas which is not very often here in our area...
Old May 30, 2016 | 02:52 PM
FLS103's Avatar
FLS103
Agreed with lower milage with E10. Non ethanol gas is readily available here and that's all I run. Had to use E10 for two refils on a road trip and noticed about 20 miles less per tank.
Old May 30, 2016 | 11:09 PM
balloo's Avatar
balloo
Interesting reports.
My 2008 Heritage, is stage one, with V&H fuel pak.
I do not ride hard, and always ride single.
Recent trip included one mountain pass
Filled the tank 6-times, I did an average of 47.3
This was all hwy. miles and almost never over the posted speed limits.
Not sure of the average mph, but I would guess 50, as I was on a freeway for only about 150-miles.
No wind, but lots of rain.
Also, I would never plan my gas stops on 47.3/mpg
Old May 31, 2016 | 06:38 AM
chrisarrington's Avatar
chrisarrington
I installed a set of VIEDS on the 08 Custom and setting it around 40% I got 44.5 through the last tank. I might try 50% and see what it does for a tank too.
LowRider68
General Topics/Tech Tips
May 31, 2015 09:56 PM
MikeBel
May 5, 2013 07:32 PM
JWD
May 1, 2012 07:30 PM
KCKid61
Apr 24, 2012 12:01 PM
Newharleylover
Jan 4, 2012 08:26 AM
