Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
What the hell? I have read and learned a lot here but something's been picking my *** for a while now. I've read a few guys posts claiming their fuel mileage "dropped" to somewhere in the 40 mpg range or slightly higher after they put in new cams, ac and tuner. My stock RKC's average mileage is about the same as theirs! I'm ordering new slip ons, a new ac and a Cobra Fi2000R the end of this week. So what can I expect from that point onward? 30 mpg? Then what if I decide on a cam later on? Is it maybe different altitude or something?
It's all in the tune brother. Realistically you shouldn't drop any MPG. Look at it this way, a higher perfromance bike doesn't have to as hard to acheive normal riding. I have a 110" with head work, ported throttle body and all the goodies, making over 120 HP, on a trip loaded down running 70 MPH i'll get 44 MPG. normal city type riding i'll get closer to 40. When you get your parts, make sure you do some research and find a tuner that knows what he's doing. It makes all the difference in the world.
I have several tuners to pick from. There's a few fully equipped indies around. I'll be sure to pay them a visit when I have all my ducks in a row. I don't feel that I need an assload more power (but 120hp would be SWEET!) but when me and my wife are on it and have the bags loaded, my opinion's that my bike feels pretty damned sluggish and our combined weight is about 400 lbs. The right cam may be in order if this stage 1 doesn't pan out because it doesn't have the low end grunt I think it should have. It's the mpg other guys have that kind of threw me for a loop.
I understand your concerns, you may end end up with a cam. The stage I will make some pretty good improvements over your stock ride, so I guess time will tell. I'm not familiar with the cobra "tuner" you are getting so I can't comment on it's capabilities. I did a quick read on it and see it takes the o2 sensors out of the equasion. It does not appear to be tunable, just plug and play. If this is the case, a dyno tune will be out of the question and you will be at the mercy of the cobra unit itself. If you are contempltaing a dyno tune, you may want to consider looking into a TTS mastertune or a SEPST instead of the Cobra. They are both fully tunable and retain the factory o2 sensors that will help you keep your fuel economy up where you want it.
Stage 1 with SEPST and get a solid 45-46 mpg each tankful, and that is with 10% ethenol gas. No dyno, just Smart tuned. Once I got my VEs all trued up, I used a similar target AFR table like what harleytuner posted in the SEPST sticky. Good power, good mpg and cooler running bike.
Glad that AFR table is working for you. Adjusting the AFR tables after tuning the VE tables is a step alot of tuners overlook. The proper AFR and ignition table adjustments are crucial to a properly tuned bike.
I even ran some recorded runs, non-smart tuned, through the My Tune program to see if it adjusts the timing any. It did pull a few degrees out at a few cells but not much. I didn't even notice any pinging, but I think the system can catch dentonation even before we hear it.
Thanks again for all your time (and all the others) for helping us out! Getting to know the tuner application and how tweaks made in different tables is a ton a fun and just increases your knowledge of EFI systems.
Cobra offers the Fi2000/o2 as well. It's a little more money but nothing to worry about. I'm sure it will be something tuneable but maybe I'll see how my stage 1 works out. And if I still feel the bike's too damned sluggish I will work the cheap bastard part of me out of the equation and spend the money to do it right. It's not like I'll be buying a tuner every year or anything.
I do not think Cobra has a unit that re-maps or reflashes the ECM. I bet the Cobra unit just changes the output from the stock ECM and changes the injector pulse widths. I think some of the Cobra units you can adjust "pot" screws and maybe one of pot screws it can impact your MPG, but you might need to call Cobra as they have different Fi unts now.
