Lifter stuck in bore
Old Jun 16, 2016 | 08:32 PM
stal94gt's Avatar
stal94gt
Bad advice jm35ny. It will probably be cheaper to buy a used right side case and have it installed than paying the dealer to repair yours. Once the cases are split I would upgrade all the bearings and re-ring the Pistons if they look worn and the gap is too far out. Once rebuilt it will run like new and have plenty of life to make it another 120+k plus miles
Old Jun 16, 2016 | 08:59 PM
jm35ny's Avatar
jm35ny
I agree its probably not the best option just a cheap fix. If you have the funds a rebuild is a much better way to go
Old Jun 16, 2016 | 11:41 PM
vheflin's Avatar
vheflin
I wasn't replacing the lifters. I initially was going to check and readjust the valves as the valve train was ticking a bit louder than normal but I was unable to properly adjust the exhaust pushrod. i then easily removed the intake lifter but the exhaust would not come out, nor could I rotate it after removing the anti rotation pin. No way would I just reinstall the lifters and ride. If I decide to fix it, I'll do it correctly and redo everything while I'm in there. I sure hate to do anything other than the bottom end repair as my last tune up showed 190 psi and
Old Jun 17, 2016 | 12:50 PM
Wide Open Cycles's Avatar
Wide Open Cycles
Former Sponsor
It's hard to tell, but here is a picture of it. It is repairable but like stated, it would require splitting the cases to do it right.
Old Jun 17, 2016 | 04:35 PM
Campy Roadie's Avatar
Campy Roadie
I'm sorry to hear your bike is gonna need some expensive/extensive work. I'd do as you said and buy a back up bike. I keep two at all times so nothing interrupts my riding season. By doing that you can perform the work your self (at least the taking apart and putting together) and save a little money.
Old Jun 24, 2016 | 10:19 PM
vheflin's Avatar
vheflin
Already did. I picked up a 2016 sportster 1200 custom last Friday evening. One heck of a fun ride. New engine on the way for my fatboy.
Rattletrap 96
Dec 16, 2013 03:38 AM
Totally Bored
Jun 29, 2011 06:01 PM
harleydavidone
Apr 18, 2011 10:56 AM
RidemyEVO
EVO
29
Aug 10, 2009 10:51 AM
jdusty21
Ironhead
11
Jul 16, 2007 06:53 PM
