teardown\inspection advice needed
Seems previous owner tried to stop rear base gasket leak with epoxy.
You should replace the wristpin bushings for sure. Of course valve seals with a correct, 3 angle seat grind. If the seats are cut so the valve contact area is too wide, your top-end will be noisy. It'll likely need at least the exhaust valve guides replaced
I think John covered everything else very well
so if my math is close, 90,000 miles usually isn't a problem on an Evo bottom end, so check everything to your satisfaction of specs and a good top-end refresh will probably do you well.
Oh ya I rode back to hotel we were staying at and next morning ( this morning ) blew speedo cable first thing so had to go on tack.
If you still have problems then you need to look at your tranny linkage for loose/worn linkage or perhaps the shifter pawl is out of adjustment, also make sure that your primary chain is adjusted correctly. If that doesn't fix the problem you may have a problem in your clutch pack. Hope this helps.
