Need help solving problem
Old Jun 25, 2016 | 05:59 AM
  #31
splattttttt's Avatar
splattttttt
Alright T-Bone... Long shot here, but it's possible you head temp sensor may be acting up?
We've gone through most if not everything else. But this part has gone unlooked.
Old Jun 25, 2016 | 08:29 AM
  #32
t-bone 702's Avatar
t-bone 702
After checking wire and connectors, sanding 3 prongs on Ign. Switch, gonna go for a ride in a bit. Will give update then. Thanks Everyone.
Old Jun 25, 2016 | 12:44 PM
  #33
HDmikie's Avatar
HDmikie
Subscribed.....Hope it's something simple like Ignition switch.
Old Jun 25, 2016 | 09:27 PM
  #34
splattttttt
found this for you. Maybe you can get more out of it, but seemed worth checking... Link http://www.springer.ws/sertmanual.pdf
Heat Management Sytem
The ESPFI systems on 2001 and Later EFI- equipped Softail models, 2002 and Later EFI- equipped Touring models, 2004 and Later Dyna models and 2004 and later V-Rod models
also incorporate a sophisticated heat management system that operates in three-phases to
keep things cool in extreme conditions.
Phase I:
If the ECM detects engine temperature above approximately 300°F while moving
or stationary it reduces the idle speed. A lower idle speed produces fewer combustion events
per minute and that reduces engine heat.
Phase II:
If the ECM detects an engine
temperature that’s still drifting higher while moving or
stationary it richens the AFR. An increased amount of fuel in the air/fuel mixture has a
cooling effect on the engine.
Phase II
IIf the ECM detects an engine temperature that’s still drifting higher while moving or stationary it directs the fuel
injectors to skip, (only when the bike is stationary) and not deliver fuel on every intake stroke.
This limits the number of combustion events taking place,
which produces less heat.
The 3-Phases just described function seamlessly, and the rider may not notice the transition
from one phase to the next.
Old Jun 26, 2016 | 09:26 AM
  #35
the blob's Avatar
the blob
The op's bike is carbureted like mine, we don't have an ecm or engine temp sensor. All we have is an ignition box and a few other timing sensors amongst a few other relays and fuses, circuit breaker.
Old Jun 26, 2016 | 11:09 AM
  #36
t-bone 702's Avatar
t-bone 702
Yea its Carbed. Just got back from ride, when bike got hot same ol crap. Bike doesnt die, idles just fine, something is losing its connection, I can go through 1st and 2nd barley, and it will engage again in 3rd or 4th gear but cuts in and out, gauges still glitching. But again ride was great to temp reach full riding temp 180-200.
Old Jun 26, 2016 | 11:50 AM
  #37
Diverrick's Avatar
Diverrick
It might help to narrow your search, if you pulled one fuse at a time and rode it after each try, that way at least you can know which system it is coming from. Start with the easy stuff like lights, horn, etc. Isolate which system is failing to make your search for the cause easier. Of course you can't do that to the motor systems, but seeing as it is carbed anyhow, no need to power the EFI system at least.
Old Jun 26, 2016 | 02:50 PM
  #38
t-bone 702's Avatar
t-bone 702
Are you saying when it starts acting up pull a fuse (one fuse at a time) ride it without the fuse in and see if it stops acting up.
Old Jun 26, 2016 | 04:13 PM
  #39
Diverrick's Avatar
Diverrick
yes, exactly! It narrows the possible failure point to a single circuit hopefully. Be careful though, as riding without brake and signals is not legal, but it would eliminate a lot of circuits. I'd find a quiet back road somewhere and spend a bit of time messing with it. Clearly it is electrical. So the more systems you can rule out, the better chance you will have of finding the cause. Sometimes you have to find out, what it IS NOT, to find what it is. Other than that your flying blind and throwing parts at it, which can get expensive quickly.
Old Jun 26, 2016 | 06:35 PM
  #40
t-bone 702's Avatar
t-bone 702
Diverrick, if u were here id give u a Bear Hug, I cant thank you enough. Did as u said one fuse at a time, got to lights fuse and problem was gone, kept riding for almost 3 hours with no problems. Will re-wire lights tomorrow. Again, Thank You Brother.
