How do i erase LO RNG code on my fatboy Lo
Old Aug 6, 2016 | 11:29 AM
dfwhockey17's Avatar
dfwhockey17
Originally Posted by Mugsy666
Hi guys
It turned out to be dirty negative wire connection. ... starts great and no codes.. i hope no damage to anything...
I am glad you found what the problem was. Next time don't start 3 threads for the same issue. I posted this in one of your other threads:
"First, I know you said the battery is new, but new batteries are not always good. What is the voltage on your new battery, and what does the voltage drop to when you hit the starter? Second, check the battery connections on both sides of the cables, and tighten them on the battery with a 10mm wrench, not a screwdriver. Low battery voltage will make the electronics on the bike erratic and give you odd codes at times. Confirm the battery is good, then we can go on from there...Rule out the easy stuff first."
Now get out there and ride!!!
Mugsy666
Aug 3, 2016 10:38 AM
Gijoe11
Feb 21, 2015 06:58 PM
Fredtoro
Apr 19, 2014 02:03 PM
Wabbit
Apr 18, 2014 12:59 PM
cjbruno
Mar 7, 2011 10:32 PM
