Springer Wheels
Old Aug 9, 2016 | 09:41 PM
panhead_pete's Avatar
panhead_pete
Default Springer Wheels
Are all Springer front 21" wheels the same?
Did they go to a 25mm front axle at some stage?
Have a 92 and may need a front wheel for it
Old Aug 10, 2016 | 06:23 AM
hspring03's Avatar
hspring03
84-99 evo will have the same bearing.
00-06 Twin Cam will have the same bearing.
07- mongrel
08-up
You're best looking for an Evo wheel 84-99
Old Aug 10, 2016 | 02:27 PM
DC Mike's Avatar
DC Mike
07- mongrel
08-up
BUT. You have a 3/4 axle on your bike, so if you wanted to use a 2000-2006 wheel with sealed bearings you would only need to swap spacers and you'd be down the road. Keep in mind, you MUST use a springer wheel. The offset is not the same on a glide front end.
Mike
john_182
Wheels/Tires
Jun 16, 2024 10:01 AM
PAULB63
Jul 13, 2016 08:52 AM
ecsjr
EVO
Nov 29, 2013 05:52 AM
blastonerski
Sep 12, 2013 07:04 PM
ozzyinmyhead
Aug 26, 2009 08:49 PM
