Wheels for a Springer?
Then check fender clearance with tire height.
It's not bolt job and most dealers aren't interested in too much custom work. Especially if they don't have a machine shop they won't want to mess with it.
Most can fit though if willing or want to bad enough.
Good luck.
that the wheel needed to be engineered and built for a Springer, that I just couldn't
use any old wheel.
Something about the extra weight of the frontend on the Springer.
A couple of guys on here took exception to this recommendation once before, but it was
my butt going down the road on the bike.
I would check into the wheel in question before I did it.
Harlie Rider
You are right! Hiro (the mechanic at Harley) said he wouldnt do it because its not safe to do it. Now i gotta look for a used Springer OEM wheel...
use any old wheel.
Harlie Rider
Call around all the major vendors PM, ride wright, etc... Springers have been around a long time and no one has a product line called the "Springer" wheels. Have you not seen all the various springers out there and the various wheels on them? Look at the Bad boy Springers...they are on a spoke wheel 2.15 wheel at 21 inch. Is that made of super strength steel? Come on guys not true and don't always believe the dealers. I have heard the most crazy stories from those guys.
But do what you got to do. If that were true all springers would have the same wheels and limited options. If you ask me, please go talk to someone else that is more informed than who you are talking to over there.
As stated in first message, take the wheel you want to install to a custom motorcycle shop or machinist and they will put in the axle spacers, sleeves and bearings to fit your bike requirements press them and it will fit. There might be a few exceptions such as the hub depth and bearings, but as stated most wheels can be made to fit. The fitment is not something someone can just say it won't fit by reading off the fitment on the harley catalog. What the dealer are saying to you is the bearings that come from Harley are not designed to fit the springer axle and they don't custom fit it. It is not some cheap risky change out either. All it really is doing is changing out the bearings and sleeves and pressing it together just like required on an oem wheel that came with the correct spacers for that specific wheel. For example Harley made "x" wheel and the only spacers for "X" wheel are 25mm from the factory. Therefore this wheel will only fit "A,B,C" models that fit that 25mm and spacing. So they won't list the Springer wheel as an option. But as stated, any custom shop will just press in the correct stuff to make it fit the model needed. It doesn't have to do with durability of the wheel.
I have had this done before. my point is there are no "springer" wheels that are made different. Just the internals... these can be adjusted for any model with the exact same specs as the previous one, just a different internal axle size. There are a few exceptions because of the wheel machining and how the bearings fit, but even then there are options with reducers, etc...
Good luck. not trying to sound like a know it all friend. If you got a wheel you want to put on your bike, i say talk to a few installers in area or make a few calls to some custom shops and they will get you the correct information.
Blaster - RockinRed is right. I bought wheels for my 03 Heritage Springer from Sinister Wheel. I told them my bike, mainly the year and family, and it came with the right bearings and sleeve pressed. I reused my stock wheel spacers in the stock locations, without issue.
There is no wheel that is special to a springer. As you know, the springer is just the front suspension. No special machining was involved in that case. But like RockinRed was saying, putting a wheel on a bike that it wasn't packed for from the get-go requires a bit of special attention.
The main point is that just about any wheel can fit any bike. As you stated it just takes a little bit work as it turns from a basic bolt on job to a custom application. Don't forget about raising the front fender if you get around to that. Just have someone do the fender arms so they don't mess with the beautiful paint.
Good luck guys.
I agree with just about everything you said debunking the springer wheel myths.
id like to add:
the "super special springer wheel" the mechanics are referring to may simply be the fx springer hub which has a drive tang on the wrong side for the speedo gear (if im not mistaken).
also: fx springer wheels have a lot of offset to fit under the offset front fender. (my rims 5/16 off center on hub, ive heard other say theirs is more).
I am with you, you can make just about any wheel fit any bike with a few parts and little persistence! my springer front is an 80s non-springer 3/4 hub laced to a 2012 blackline rim and spokes.
