Hq 120 base map
Old Oct 9, 2016 | 12:36 PM
TOMMYBLAZIN's Avatar
TOMMYBLAZIN
Throttle body i mean, not intake
Old Oct 9, 2016 | 05:55 PM
lapua8541's Avatar
lapua8541
2nd Gear
Default Hq 120 st w/ tts
Hey rob, just had a chance to read your reply. Thanks alot will try asap. Are you running the hq 113 w/ .575 cams?
Old Oct 9, 2016 | 07:19 PM
lapua8541's Avatar
lapua8541
2nd Gear
Sorry rob. Wasn't thinking before. Is your 120 from HQ ? If so what cams and tb are you using?
Old Oct 10, 2016 | 06:09 PM
Kiwirob's Avatar
Kiwirob
My 120 is built with all SE parts (case, crank, heads etc). Pistons are Mahle 6.1cc pop-up & cams are S&S 625 EZ starts with SE 58mm throttle body. Stock Deluxe pipes ATM with Khrome Werks slip-ons, & TTS. - Rob
Old Oct 13, 2016 | 06:18 PM
TOMMYBLAZIN
Will the se120 st motor fit in my 2008 rocker c, i might have a buyer for my motor lined up, if not ill post it up, its cherry, just broken literally...
Old Oct 14, 2016 | 03:05 AM
Kiwirob's Avatar
Kiwirob
Looks as though HD don't have a 120ST for the soft tail bikes, only Touring. Last years catalogue had the 120R for soft tails. You would have to bump the compression up to about 11:1 to get the best out of the cams in the 120R. - Rob
Old Oct 14, 2016 | 07:25 PM
TOMMYBLAZIN
that sucks? whats the biggest they make, I was just looking at my SE cataloug and your right
Old Oct 15, 2016 | 04:35 PM
Kiwirob's Avatar
Kiwirob
I haven't had a good look through the HD catalogue. If the 120R is still available I'd go with that but change the cams to something like the TMan 625 or 590. Better still, have your motor build by one of the performance people that frequent this site. - Rob
Old Oct 15, 2016 | 06:02 PM
TOMMYBLAZIN
who?can u direct me to a reputable builder?
Old Oct 16, 2016 | 01:52 AM
Kiwirob's Avatar
Kiwirob
I live in New Zealand, so I don't know who would be in your part of the US that is close to you. - Rob
lapua8541
The Dyno Room
Oct 4, 2016 08:57 AM
monster715
Feb 2, 2016 01:47 PM
HD Bobber
Sep 22, 2015 05:10 AM
masterblaster
Aug 17, 2009 08:45 AM
99embrey
Dec 3, 2008 05:38 AM
