Map for HQ 107 build
Old Aug 15, 2009 | 10:22 AM
masterblaster's Avatar
masterblaster
Default Map for HQ 107 build
Getting the motor done this week. Does anyone have a map for the HQ 107 with 575 cams and HQ heads they could send me to get started and motor break in? Will follow with Dyno but want a starter map.
Old Aug 15, 2009 | 10:49 AM
Phast Lap's Avatar
Phast Lap
Default HQ Build
Ok, I'm gonna set myself up for this but Kevin at HQ gave me a baseline MAP when I did my build. I also was using a SERT unit in conjunction with the HQ Protuner.
Old Aug 15, 2009 | 10:50 AM
Ultra61's Avatar
Ultra61
Jerry, You probably should mention what tuner your using...
Old Aug 15, 2009 | 10:54 AM
masterblaster
Duh, thanks Ultra, I will be using the SEST
Old Aug 15, 2009 | 11:02 AM
Phast Lap's Avatar
Phast Lap
Default HQ Build
Send a PM to GliderXXX he has a HQ 107 build. He may be able to help you out.
Old Aug 16, 2009 | 08:58 AM
masterblaster
Thanks PM sent.
Old Aug 16, 2009 | 10:38 PM
GMONEY220's Avatar
GMONEY220
Riders backrest,matching clutch for the added tq/hp,hmmmm oh yeahhh Brass Giblets!!!
This is a kick azz package and let me tell you,that front end wheel lift off the ground!!!!Just rode my uncles road king with the hq 107,man thats a mean summa-biatttch.Cant wait to get mine.
look up lynATL,he has this kit as well.
Old Aug 16, 2009 | 11:38 PM
CigarCritic's Avatar
CigarCritic
I have two maps you can have....BUT, you must have the old Race Tuner to use.
I am not happy with either map but they will get you broke in.
FatCat
Bub7's TD
Old Aug 17, 2009 | 06:09 AM
timvan's Avatar
timvan
A base map may be great for the first few miles....but make your tuner start from scratch..
I made this mistake with my TTS and after a retune with the same exact bike...I gained 4hp/3tq
The origingal tune had a few generations of changes that nobody knew about.
Old Aug 17, 2009 | 06:51 AM
masterblaster
Hehe got the backrest, born with the Giblets, trying the SE clutch spring first if that aint good enough will do a whole SE replacement.
