1997 FLSTC Throttle Lag
Old Oct 18, 2016 | 10:40 AM
JRH24's Avatar
JRH24
2nd Gear
Default 1997 FLSTC Throttle Lag
I have a 1997 FLSTC
S&S Super E Carb
Remainder is stock
After a long ride last night with no issues, I started up the bike this morning. No problems. Starts and idles just fine.
However, when I roll on the throttle. There is a lag and very little acceleration. I made a lap around the block and had the same issues in gears 1, 2, and 3.
Any help on where to start troubleshooting would be helpful. Thanks
Old Oct 19, 2016 | 12:46 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Clutch is slipping.
Old Oct 19, 2016 | 01:21 AM
Yamaharley's Avatar
Yamaharley
Are the throttle cables loose?
Old Oct 19, 2016 | 05:36 PM
Hey Man's Avatar
Hey Man
If the clutch adjustment turn out to be OK, drop the carb bowl, pull out the jets and make sure there's no piece of crap stuck in them. Then make sure your air mixture screw is properly adjusted. Finally, check to be sure your accelerator pump adjusted properly? You may also want to get a look at your spark plugs and check for lean or rich conditions.
Old Oct 20, 2016 | 04:49 PM
LXT's Avatar
LXT
Accelerator pump plunger? does it happen only under load? or like said above carbon or dirt buildup but that usually causes flooding or lag when taking off.
HighonHarley
Aug 5, 2015 11:58 AM
ryamatt
Jul 7, 2013 08:14 PM
hog85
EVO
18
Aug 26, 2011 08:09 AM
mulch63
Exhaust System Topics
20
Jun 27, 2009 01:39 PM
guitarbug
Jan 19, 2009 04:07 PM
