Belt to drag chain conversions for 09 Deluxe
Old Nov 15, 2016 | 06:57 PM
Johnny Goodlife's Avatar
Johnny Goodlife
Question Belt to drag chain conversions for 09 Deluxe
Searched the forums and found a few threads. I just wanted to see if anyone has used Zipper's Drag Chain Conversion for the Deluxe.
This is purely for looks if anyone asks why I would want chain over belt.
Thanks in advance.
One of the threads I found
https://www.hdforums.com/forum/softa...ain-drive.html
http://www.zippersperformance.com/ch...-softails.html
SOFTAILŽ 6 SPEED* ('07-'15): Choose between 24-25 teeth on the transmission sprocket; on the rear 46-65 (aluminum), 46-49 & 51 (chrome steel) and 49 & 51 (zinc steel). Suggested ranges: 24-26 front, 48-55 rear. Sizes outside of these ranges may require modifications for proper clearance. *Due to clearance limitations, chain conversion kits for 6 speed SoftailsŽ are only available with drag race chains
Old Nov 16, 2016 | 11:55 AM
Next In Line's Avatar
Next In Line
Chains require a lot more maintenance than a belt. Figure on changing both sprockets every other chain replacement.
Old Nov 16, 2016 | 06:22 PM
Johnny Goodlife
Not a problem. Other than cost, changing a chain is not a huge issue.
Ill post up pics when I get it done. Lots of work this winter
Old Nov 16, 2016 | 11:33 PM
Next In Line
Changing the front sprocket will be a problem unless you are able to easily access it without removing the outer & inner primary.
Old Nov 17, 2016 | 04:15 PM
Tom84FXST's Avatar
Tom84FXST
Running a modern o-ring chain... on steel sprockets is not a big deal, and not the huge maintenance nightmare...that a lot of people who have never run one would lead you to believe.
Running a "drag race" chain on aluminum sprockets would be a PITA...I would research why an o-ring chain won't fit.
Old Nov 17, 2016 | 05:22 PM
misfitJason's Avatar
misfitJason
^ my guess is the 200 tire alignment with the chain eating into the primary
Old Nov 17, 2016 | 08:08 PM
Tom84FXST's Avatar
Tom84FXST
Deluxe and several other models did not have the 200 tire...website says "6 speed"...but is also says it's o-ring kit will only fit 2006 with 150 tire.
My bet is the o-ring chain will work fine on the deluxe...an o-ring chain is over an 1/8" wider than the 20mm belt used with the 200 tire.
Old Nov 17, 2016 | 11:28 PM
Lundee's Avatar
Lundee
I've been running an O-ring chain and a 200 conversion for 5 years. Still in the same chain and sprockets. Both look like new, & I am not nice on my bike at all. Both sprockets are steel. I'd steer clear of aluminum. I just slap some chain lube in when I do an oil change. Only maintenance I've done. Check out Night Rider I believe they still make a conversion kit.
Old Nov 28, 2016 | 06:27 PM
Johnny Goodlife
Thanks for all the extra info. Seems like PBI is the company to grab sprockets from. Still getting more info and finding parts. I agree with running the o-ring chain.
Do you guys know what tooth you are running in front and rear sprockets?
Old Nov 28, 2016 | 06:36 PM
Johnny Goodlife
also, awesome thread regarding the same topic
https://www.hdforums.com/forum/dyna-...on-thread.html
