New to harley
oils? 3 differant kinds
engine oil, is in the side contaner,, that feeds just the engine,, red line 20w50,,,
any luck with castrol 20w50????? or royal purple???
primary,,, clutch and ????what to use in here,,, same as above??????
trany,,, ????ATF ???? what to use in here,,,,,says to only use harley brand oils,,, but would like your thoughts??????AM I IN THE RIGHT DIRECTION???
i got this bike from a repo dealer,,,,{sorry bro} and know nothing about it...
has rineheart short pipes,,, so thinking it might have a stage 1with the chip,,,any way to tell,,,thx for your thoughts
As mentioned service manual (& parts manual) is golden if doing you're own work.
May I make a suggestion....? If you use the search feature on this forum, you will have more reading than time in the day, for your basic questions like what fluids, basic EFI questions, and just about anything else that pops into your mind...
It always helps to get the general, oft repeated, info from a search (there's tons of info on basic questions). Then if you don't find your answer, it allows you ask more specific, technical questions on the topic...
Good luck, enjoy the ride....
That year has a couple known issues that are fairly easy to deal with for someone such as yourself that wrenches. There's the spring loaded cam chain tensioners that is a maintenance item. I would suggest looking into that fairly soon to avoid trouble.
There's also the plastic fuel pressure regulator housing inside the tank. Prone to failure. That item is the only thing that has left me semi stranded. A company called Trask makes an aluminum housing. If you get into the tank to change the fuel filter, do yourself a favor and swap that piece out.
Then, just ride and enjoy!
