2014 cvo breakout limportant mode
Old Nov 24, 2016 | 08:21 PM
Shane14cvo's Avatar
Shane14cvo
Stage I
Default 2014 cvo breakout limportant mode
Hoping someone can help
bike in limp mode diagnostic code says throttle body issues
replaced throttle body no change any ideas
Old Nov 25, 2016 | 01:17 PM
UHDhog's Avatar
UHDhog
What are the codes? List them here.
Old Nov 26, 2016 | 02:13 AM
joebotics's Avatar
joebotics
Hey Shane... what do you mean with Throttle body? do you mean the twist assembly that goes inside the handlebar?
The Fly by Wire on Harleys has TPM (throttle position sensor) in the intake manifold to detect the position of the intake butterfly valve, and the throttle assembly that goes in the handlebar also has two sensors.. all that info is fed to the ECM.. limp mode happens when the ECM cannot reconcile the data being fed by the sensors (most likely because the sensors in the handlebar or the intake manifold went bad).. Harley engineers in the their infinite wisdom decided to seal the TPM sensor inside the air intake manifold.. so if the TPM sensor goes bad.. you have to replace the entire air intake manifold!!!!.. to make matters worse.. the TPM is electro-mechanical (inside it has two potentiometers)... so well.. they eventually wear out.. I am still baffled by that decision made to seal the TPM inside the manifold.. the other bikes without Fly By wire but rather cable operated throttle assemblies have the TPM sensor installed outside and easily replaceable..
Here is a good article on Fly by Wire technology on Harleys:
http://ridermagazine.com/2009/02/12/...ottle-control/
Twelve point
Jun 23, 2016 12:47 PM
saz
Engine Mechanical Topics
May 17, 2016 10:22 AM
olongapo1
Apr 14, 2014 12:58 AM
PappyUSMC
May 7, 2013 10:21 PM
x1rider
Jan 8, 2010 08:49 AM
