what was my problem?
Old May 31, 2007 | 10:26 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Default RE: what was my problem?
I still think you were in 5th gear. [sm=smiley36.gif]
Old May 31, 2007 | 04:41 PM
20NightTrain03's Avatar
20NightTrain03
yeah i dont get the low power part either, but it was definetly a little sluggish
i will prolly break 19K miles this weekend on the bike.......since i had to adjust the chain almost all the way to the max to get it within spec i am thinking me needs a new one soon, or maybe i will go with that open belt drive i have been eyeing up
Old May 31, 2007 | 04:42 PM
20NightTrain03
ORIGINAL: stro1965
Do I get a cookie or something??? C'mon!!
i'll do better than that, meet up with me in NJ and you can buy me a beer. errrrrr.... i mean i'll buy you a beer
LOL
Old May 31, 2007 | 09:43 PM
stro1965's Avatar
stro1965
Hmmm...THAT would be a heck of a ride from Nebraska!
Old May 31, 2007 | 11:26 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: stro1965
He's a cheapskate,he's counting on it being too long a ride for you pryone free beer out of him.
J/K But I still don't see how you can be down onpower from a loose primary chain. If it was a cam drive chain I could see the enginedoing wierd and strange things, and even causing it to pop out of gear from the missfires. But a primary chain doesn't, or at least it shouldn'thave any direct effecton overall engine performance. Something very strange going on here.
Old Jun 1, 2007 | 12:00 AM
Oldtimer of NM's Avatar
Oldtimer of NM
Had a problem like that on an Ironhead. It had lost the nylon shoe on the primary tensioner and it had wedged between the chain and the case. Since this was an early one that had to have the pimary opened up to adjust the tension, the problem was obvious. Since he says that the adjustment is maxed out, he could have something like that going on.
Old Jun 1, 2007 | 09:37 AM
Geoseismic's Avatar
Geoseismic
It does not have any effect on enging performance however, the primary chain transfers power from the motor to the gear box. An impropertly adjusted chain will reduce the amount of power transmitted through the gear box to your rear wheel. If you can picture a belt and pully arrangement, when the belt gets loose the driven pully will slow down in relation to the drive pully. If the belt gets real loose, it won't even turn the driven pully.
Old Jun 1, 2007 | 10:45 AM
Geoseismic,
I think you missunderstood my question, I understand and fully appreciate how the system works better than you think. My question was in relation tohow it affected his perception of delivered power.
The jerky operation, and inability to deliver power smoothy are common symtoms of a loose chain condition.
Unless thechain wasway over tightened inducinglarge amounts of parasitic drag I still don't get thelowered power output.
The onlylogical explination I can come up with is that it DID NOT actually affect the true power output of the engine. The loose chain induced jerky operation just disguised that fact.
Aloose chainis unable totransmitpower smoothy unless or until itwas placed into a continuous load condition great enough to hold the chain in a constant state of tension. Such as accellerating from a light or cruising at speed down the highway.
When it isn't under a continuous load (as in lowspeed manuvers) it gives the "missimpression" that the engine is down on power. It isn't really down on powerit just requires more than normalthrottle settings to generate the tension required toprevent or limitthe chains erratic flopping motion.
Old Jun 1, 2007 | 12:48 PM
20NightTrain03
both you guys pretty much summed it up!
thats exactly the way it was acting
Custom Zach
Jun 14, 2013 03:13 PM
PHX Sporty1200
Engine Mechanical Topics
Aug 27, 2012 10:36 PM
jayride
Mar 28, 2010 09:59 PM
Shalomtou
Sep 30, 2008 08:21 PM
SoftailMatt05
Exhaust System Topics
27
Sep 18, 2008 09:09 PM
