wood cams
Old Jun 4, 2007 | 06:27 PM
79Lowridr's Avatar
79Lowridr
4th Gear
Default RE: wood cams
Dalton,
When you mentioned noisy what did you mean? I've got top end noise in a '97 Heritage I bought recently and I know it's got a cam, but that's all!
Thanks,
79lowridr
Old Jun 4, 2007 | 08:25 PM
06hog's Avatar
06hog
Yeah Loud1, I got WOOD! and its Big and BAD too !!!
Old Jun 4, 2007 | 09:00 PM
mike01844's Avatar
mike01844
how much did it cost for the cams?
Old Jun 4, 2007 | 09:10 PM
Dalton's Avatar
Dalton
ORIGINAL: 79Lowridr
Dalton,
Thanks,
79lowridr
Just more mechanical noise. The 03 RKC had Woods gear drive cams with .575 lift which is considered a high lif cam. Higher the lift, the faster the ramps (ramps are the transition area from the flat of the cam to the tip of the lobe) and the faster everything travels, pushrods, rockers and valves. Sometimes due to fast ramps you will have some valve clatter that you just cannot adjust out. This can also happen in lower lift cams with aggressive ramps.
Current engine is running a Woods .650 lift cam (very high lift) and again I have some valve clatter that I cannot adjust out, but it is not much worse than stock and I have just gotten used to it.
If you have a '97 model and the cams have been changed you more than likely have adjustable pushrods. (Stock engines have fixed length pushrods) It wouldn't hurt to adjust the valves and see if it reduces or eliminates the clatter you are talking about. Valve adjustment is a pretty easy process.
Old Jun 5, 2007 | 10:19 AM
06hog's Avatar
06hog
ORIGINAL: mike01844
I think I paid like $335 for the cams (TW-6) and they put them in for free for some other work I had done also.
thewholehog
Exhaust System Topics
50
Jun 3, 2020 08:01 PM
chgofirefighter
Feb 2, 2017 03:05 PM
dzzbob
Oct 25, 2015 09:34 AM
mgmmgm
Sep 6, 2012 05:49 AM
TexasFLHX
Mar 12, 2010 09:20 PM
