O2 sensors
Old Apr 6, 2017 | 09:36 PM
Lo 1's Avatar
Lo 1
Default O2 sensors
Getting ready to install a Fatcat on my Fatboy S. do the o2 sensors need to be disconnected or can the be removed from the pipes after loosening the stock exhaust and installed before tightening the new down? I understand the rear o2 connector is a PITA to access.
Old Apr 6, 2017 | 10:00 PM
Gommee's Avatar
Gommee
Devil's Advocate
You can unplug the O2 sensors and remove them with the exhaust. Install them into new exhaust, mount exhaust and plug back in.
Old Apr 6, 2017 | 10:47 PM
Lo 1's Avatar
Lo 1
Yeah but how hard is the rear plug to get out? My worry is that I get to that sucker and I'll be stuck. I watched a video with a softail slim and the rear o2 connector was under the seat. Then I watched a video with a fatboy and the rear was under the oil tank with no easy way to access it.
Old Apr 6, 2017 | 10:55 PM
hog-doc's Avatar
hog-doc
remove seat, remove battery, unplug O2 sensor and pull it out from under oil tank, install by reversing the order!
Old Apr 6, 2017 | 10:58 PM
Gommee's Avatar
Gommee
Devil's Advocate
Exactly how I did it. Too easy...
Old Apr 7, 2017 | 08:16 AM
Lo 1's Avatar
Lo 1
Roger that, guys. Thanks!
Old Apr 7, 2017 | 07:17 PM
Mr.Softy's Avatar
Mr.Softy
Removing the rear sensor really isn't hard at all. Just take your time and go one step at a time.
Old Apr 8, 2017 | 10:52 PM
Lo 1's Avatar
Lo 1
Fatcat is installed. Rear o2 sensor was under the seat at the front of the battery box and was no problem at all. That Fatcat is super loud and I'm lovin it.
Old Apr 9, 2017 | 06:43 AM
misfitJason's Avatar
misfitJason
When you put the o2 sensors back in remember to use anti seize that is o2 sensor compatible
gottah8me
May 2, 2017 08:37 PM
bsibold
Jun 21, 2013 04:12 PM
ScReaMnEagLE22
Exhaust System Topics
Jul 8, 2009 07:48 PM
04RoadKing
May 26, 2008 09:12 PM
Bill918
Dec 31, 2007 03:59 PM
