Project Bike: EVO or 88TC?
(belongs to a friend of mine)
my 00 Heritage, 88" TC-B 203 camzz, jetted carb, Thunderheader
EG, just a tad quicker (same gearing? EG 80lbs heavier?)
and my bike is no slouch (for what it is- I haven't had too
many people blow smoke in my face)
TC's come with more cubes (THATS the advantage)
So 100 " Evo ???!!!!!!
Oh. His fillings are fine. So are mine. Thanks
EG, smoother on freeway (above 70)
TC Heritage smoother everywhere else.
Funny too that Harley went back to single cam. Hmmmm?
The EVO does vibrate a bit more, but is a darn fun ride. Read my words built RIGHT they are a strong engine. But let bubba do it good luck. Shoddy work turned a lot of EVO's into trash.
Lot of bikes have come and gone over the years all of them good some great. My 1996 EVO FB is still here.
You will need to do a little more leg work getting the right parts, A little more home work on how to do some of the work it may need. In the end if you go EVO you can end up with a cool ride and one that will stand up well.
1996 FB.
I researched both motors extensively and concluded that the Evo motor was without doubt the one to get. I bought a 94 with 40k miles so its been used fairly regularly like all engines should be.
I am not adverse to doing my own maintenance and repairs within reason and the ironhead has enjoyed top end rebuilds, timing / pushrod adjustments and clutch plates replaced. The evo retains what is basically the shovelhead 1340 bottom end but with a far superior top end. It runs cooler than the twinkie and has less serviceable items hidden away in the motor. I didn't like the idea of one of those tensioners causing bits of plastic to block the oil pump and cause oil starvation.
The twinkie is faster but not by much and the Evo has plenty of power in stock trim. It has a far nice sound as well. To me it sounds similar to the older big twins.
Nothing wrong with either choice but for me the Evo was without a doubt the one to go for!
As for my '95 FXD, it's the least tricked BT from the factory but it starts, stops within it's abilities & actually goes very well with more than enough power for my ageing riding needs.
I would like to see these amazing bikes kept on the road.
Best from New Zealand
Had this, it did everything better.
Sold it for this
Is slower, less gears, takes longer to warm up, vibrates more....and I just Love it.
But! Both have more soul than my twin cam, even though I cant fault my twin cam at all.
