Twin Cam top, Evo Bottom??
Old Dec 5, 2007 | 01:42 AM
skullcrusher's Avatar
skullcrusher
Default Twin Cam top, Evo Bottom??
Hey guys, my friends thinking about buying a bike. But i want some input from you guys first if you dont mind. From what i know about the bike its an 01 Road Glide. The motor is a twin cam 88 top end. And an Evo bottom end. (any thoughts on that????) Also the bike has 117K on it. but the motor only has 17K and he's asking about 10K. Any further thoughts? thanks for your time.
Old Dec 5, 2007 | 07:52 AM
CREEPSHOW's Avatar
CREEPSHOW
Default RE: Twin Cam top, Evo Bottom??
117K is alot of miles. There is still 117K on all the other parts!!! Look around there are deals out there!
Old Dec 5, 2007 | 08:46 AM
zoomie67's Avatar
zoomie67
I've heard of these frankenmotors most notably the Fatvo by Sputhe and the Merch Fatso 100" motors. They are supposed to be pretty nice for EVO bikes. I don't see how the running gear of a TCwould mount up to the EVO cases. I hope your friend is a good mechanicbecause there probably are't alot of wrench's out there that would work on it (not a bike you could just drop off at the local dealer and get it worked on).
I picked up my 2000 RG with 33000 miles this summer for 10k. I would keep looking there are better deals to be had.
Old Dec 5, 2007 | 09:20 AM
gunrunner's Avatar
gunrunner
If its not cheap, I would pass on it, could be a unreliable and hard to repair setup, plus the miles are high.
Old Dec 5, 2007 | 09:36 AM
EvilDave's Avatar
EvilDave
Unless the motor is an aftermarket no such thing as a TC top end and an EVO bottom. Check the motor serial number to see if it is a genuine HD. Then look at connection between motor cases and trans, are they bolted together with no gap (TC) space between cases and trans (EVO/aftermarket)
Old Dec 5, 2007 | 09:40 AM
huffhuff's Avatar
huffhuff
there is a position and angle difference of the pushrods ofEvos and Twin cams. lots of Pan/Shovels running around BUT Twin/Evo, not likely.
Old Dec 5, 2007 | 10:39 AM
Zimbob's Avatar
Zimbob
I saw a twin/sportster in a mag. once. Bunch of machine work there. believe I'd keep looking, better deals are there to be had.
Old Dec 5, 2007 | 11:13 AM
HogBack's Avatar
HogBack
The TC has bigger rods and the three bearings are thicker/longer;three hole oiling crank pin that is thicker; the cases are more ridgid/stronger/durable; plus the pinion shaft is about twice the EVO; ETC++++;I would have to ask why....
Old Dec 5, 2007 | 11:24 AM
Biggzed's Avatar
Biggzed
For anyone doubting this engine combination exists... check this out.
http://www.sputhe.com/fatvo%20twin%20cam%20case.htm
I've read about them, but never have seen one. Not sure if it could be done with stock Evo cases.
Old Dec 5, 2007 | 11:37 AM
Biggzed's Avatar
Biggzed
wrong thread. sorry
