Fatboy belt adjustment.
Old Jun 5, 2007 | 09:16 PM
rideaholic's Avatar
rideaholic
Default Fatboy belt adjustment.
I did a search and was unable to locate how to adjust the belt on my 2000 FatBoy. I plan on buying the service manual, but just haven't had the time yet.
I need to change my rear tire and want to remove the tire and then when I reinstall make sure the belt tension is correct. I found a spot that I can use 1 finger pressure and just touch the frame as it is adjusted currently. I also have a spring scale that I can use if there is a way to implement that. I appreciate any guidance and advice anyone can offer. Thanks in advance.
spot on frame:
without my fuzzy finger:
[align=left]Name:  DSCF0047.jpg
[/align]
Old Jun 6, 2007 | 02:19 AM
Scurvy Jack's Avatar
Scurvy Jack
Default RE: Fatboy belt adjustment.
You should be able to pull the rear axle without having to mess with the adjustment bolts on either side of the rear swingarm. Get the bike high enough in the air, pull the bolt, make sure you see which side each spacer came from, and push the wheel forward and it should come out.
Old Jun 6, 2007 | 11:13 AM
jbroughton's Avatar
jbroughton
Harley makes a little belt tension tester tool that's fairly inexpensive (I was thinking around $20 or so). I've been meaning to pick on up myself, but keep forgetting to...
Old Jun 6, 2007 | 12:39 PM
billnourse's Avatar
billnourse
Maybe this will help. To do the job right you will need a HD belt adjsutment gauge.
https://www.hdforums.com/m_132315/tm.htm
Bill
Old Jun 13, 2007 | 12:56 AM
rideaholic's Avatar
rideaholic
Thanks for the responses. I was able to remove the wheel and then put it back on without loosening the adjusters. I may pick up that tool for future use or I may just use my finger method. Thanks again for the help.
jt metal
Jul 23, 2019 11:26 PM
d-streetglidr
Mar 24, 2017 11:35 PM
OddJob
Feb 15, 2016 10:42 AM
83 fxdg 90
Shovelhead
Jun 17, 2010 02:23 PM
