Oil Filter Question
Old May 16, 2017 | 09:03 AM
tmilo1000's Avatar
tmilo1000
I have used HD filters and K & N filters. No problems with either. I thought about the Pro Flo filters, but it cost quite a bit and seems like a pain to clean and reuse, but it looks pretty cool. If I had a race motor and needed to check for metal chips, I'd use one.
Old May 16, 2017 | 09:37 AM
HKMark23's Avatar
HKMark23
Not trying to turn this into a personal campaign to defend my choices but; FYI, the PITA factor in dealing with permanent filter oil changes gets waay overstated.
All you do extra is prepare, along with funnels, catch pans, paper towel, wrenches, etc. etc., as you normally do, containers of soapy water and rinse water for your reusable filter. A swish in each and set the filter aside till you've dealt with the other 2 holes and your filter components will be dry enough to reinstall. Trace moisture is totally inconsequential as it vaporizes away on your subsequent ride, as you no doubt know. It all amounts to a small change in organizing the process and adds virtually nothing to the time involved. Use light colored containers for the swishing and you readily see if there is anything nasty in amounts you need be concerned about.
Dunno if all this applies to the Pro Flo filters per se but in general the whining about "all the inconvenience" of permanent filter oil changes is being done by folks who haven't used em,,,,,, "obviously".
Main reason not to use em is cost.
Old May 16, 2017 | 11:06 AM
tmilo1000's Avatar
tmilo1000
I figure I need to go through about 5, maybe 6 oil changes for a Pro Flo to pay for itself. HKMark23, you are correct I have never used one or cleaned one. I have looked at them and they are cool looking, but for me it is a personal choice of convenience. The biggest PIA for me is the location of the oil filter and fact it lays horizontal and not vertical. That along makes a big enough mess for me to clean up. If I decide to add an oil cooler and can relocate the oil filter I would consider using a Pro Flo.
Old May 16, 2017 | 11:08 AM
xwhyz1959's Avatar
xwhyz1959
Originally Posted by HKMark23
I refuse to even sip the "green" Kool Aid, never mind believe the flawed economics of them paying off over time but,, there's something confidence inspiring about being able to see the guts of your filter before using it and during changes as well. Thats why I've switched to a high flow permanent filter that is rated at 22 microns in absolute terms.
Oh,,, and the nut on top of the billet aluminum case doesn't leak.
Ditto!
JCBGlide
2014-2024 Touring Models
Aug 25, 2018 09:10 AM
Timmy B
Mar 28, 2014 05:48 PM
texashillcountry
EVO
33
Mar 4, 2013 06:24 PM
HFS
Oil Archive (no new posts)
Apr 4, 2010 05:00 PM
car5car
18
Dec 16, 2009 05:25 PM
