The Switch from Dyna to Softail?
Old Sep 12, 2018 | 05:05 PM
ABQ-Jammer's Avatar
ABQ-Jammer
All the folks on here that have changed from Dyna to Softail and loved the Softail better, it seems, changed from an older Dyna with a much smaller motor, to a newer Softail, which had several improvements to the frame, suspension, etc., that were made to them, with a significantly larger motor. I suspect that to be the majority of the reason they liked the Softail better. I also suggest that you test ride both of the same year/motor, and I suspect you will find the handling of the Dyna to be much more nimble, with further lean on the corners (if you like that, like I do). However, as has been said, the new "Dyna" actually IS a Softail, so there should be absolutely NO difference.
Old Sep 13, 2018 | 07:29 AM
uncle kebo's Avatar
uncle kebo
I've owned both separately and at the same time. I now have a 18FB 114. The new softail is such a good bike, its not funny. For a true dyna-esque ride, the Low Rider is closest in function. I found that the standard tire bikes ride differently than the big tire models. I'd just test ride em and see what you like but the Low Rider is a sweet bike..
20RoadGlidin
Oct 15, 2019 03:45 PM
jack6hd
Jun 15, 2015 11:16 PM
JayOhh
Sep 23, 2012 07:34 AM
6 gun
Mar 5, 2012 09:50 AM
jurob
May 30, 2008 03:12 PM
