Nighttrain Noise After Shut Off Draining Battery
Old May 31, 2017 | 11:49 AM
lhgdale's Avatar
lhgdale
Default Nighttrain Noise After Shut Off Draining Battery
Hello, got a 07 Night Train and there is a clicking/ticking noise coming from the throttle body area after you shut the bike off. This is with the ignition off and the run/stop button off. It will do this in a continuous cycle for 5 seconds stop then start again. I did notice if you switch the run/stop switch to run it will stop but start back when the switch is turned off.
I just put a Power Vision and tune on the bike but it's still doing the noise. The PV was put on for increased performance but I was hoping it would take care of the noise also.
Thanks for the help!!
Old May 31, 2017 | 02:16 PM
lhgdale's Avatar
lhgdale
After looking at a exploded diagram I would say it is the IAC making the noise. I read this could be due to a bad relay or water in the fuse box.
MNtadpole
Aug 9, 2015 07:02 AM
just plain john
Audio Systems
May 22, 2013 03:28 AM
cmancini26
Oct 17, 2012 06:18 PM
UCONN_DWG
Aug 14, 2007 08:35 AM
blackfinbob
Jul 19, 2006 08:20 AM
