1997 Softail shifting
Old Jun 20, 2017 | 04:28 PM
Shinerunner1964's Avatar
Shinerunner1964
Stage III
Default 1997 Softail shifting
1997 softail won't go into neutral while running
Old Jun 20, 2017 | 04:35 PM
Uncle Larry's Avatar
Uncle Larry
First thing I'd check is the clutch adjustment.
Old Jun 20, 2017 | 04:39 PM
Shinerunner1964
Stage III
It has been adjusted, it's not dragging, cable has also been adjusted.
Old Jun 20, 2017 | 05:39 PM
Uncle G.'s Avatar
Uncle G.
Did you go inside the derby cover and perform the clutch pushrod adjustment? If not, you haven't adjusted the clutch.
Old Jun 20, 2017 | 06:10 PM
Shinerunner1964
Stage III
Yes, we did go inside the derby cover.
Old Jun 20, 2017 | 07:46 PM
dibe's Avatar
dibe
Welcome to the club. My 92 likes to do that too. It gets a little better once warmed up. I find it shifts into neutral the best when coming to a stop, bump it down into first gear, and then kick it into neutral. Good luck.
Old Jun 20, 2017 | 07:56 PM
misfitJason's Avatar
misfitJason
You need to do a shifter pawl adjustment. If that doesn't do the trick then you have to start checking parts for wear
Old Jun 20, 2017 | 08:04 PM
smitty901's Avatar
smitty901
Also check the chain adjustment in the primary not hard to do.
Old Jun 21, 2017 | 06:27 AM
Uncle G.'s Avatar
Uncle G.
Both of these.
Old Jun 21, 2017 | 07:56 PM
hspring03's Avatar
hspring03
It's an Evo. they do that sort of thing....
