shifter problem
Old Jun 11, 2007 | 03:01 PM
mrs03's Avatar
mrs03
Default shifter problem
My dad has an 06 heritage classic. Last night we were going to go for a ride but his shifter started acting funny. After he shifts it doesnt spring back to the middle. It either sticks up or sticks down. Any body know what the problem is?
Old Jun 11, 2007 | 03:31 PM
06FLSTCi's Avatar
06FLSTCi
Default RE: shifter problem
I had the same problem. The shaft that the shifter pivots on sticks. I used sandpaper and re-greased the shaft.
barnyard's Avatar
barnyard
I had the same problem on mine at about 300 miles. It turned out to be a burr in the housing where it pivots. Tech sanded that down, reapplied anti-seize compound and buttoned it back up. It's over ten thousand now and no more trouble.
Old Jun 12, 2007 | 11:05 PM
Redleg1's Avatar
Redleg1
Stage III
Thanks guys, I am the dad with the shifter problem. Thanks to you taking the time to answer I avoided a trip to the dealer and the bike shifts better than ever.
Old Aug 5, 2007 | 07:14 PM
jcoers's Avatar
jcoers
I had the same problem pop up on my 07 Deluxe today. I have 2400 miles on the bike now. This shifter would not return after shifting up or down. I rode the bike later today without any problems.
How do I go about sanding the housing? I'm not sure I understand just yet.
Old Aug 6, 2007 | 01:04 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: jcoers
I believe what they are referring to is the sifter pivot point itself.
If you look at the heel/toe arm it rocks on a pivot point/bolt, that's the spot they are talking about.
Take that bolt out and see if it is rough or has machining burrs on it. Also look inside the arm itself for the same things. A little bit of work with some fine sand paper, clean it carefully and get a good coating of anti sieze or graphite grease and you should be good to go. If it still a bit sticky check the shifter rod ends to see if they might be sticking also. A little cleaning and the same kind of grease job should get you shiftingsmoothly again.
Good Luck and let us know if you find anything new, you never know if it couldhelp the next guy fix his.
Old Aug 6, 2007 | 03:33 AM
bks6721's Avatar
bks6721
I had to do the same thing on my 07 fxstc at 2200 miles.
Old Aug 6, 2007 | 08:46 AM
jcoers's Avatar
jcoers
I will give it a shot and post the results. Thank you very much!!!!
John
Old Aug 6, 2007 | 09:40 AM
Buddy04284's Avatar
Buddy04284
Barnyard and 06FLSTCi hit it right on the nose. I have read multiple posts on this subject
Old Aug 6, 2007 | 09:48 AM
Spike_96's Avatar
Spike_96
Mine isn't doing it at 300. But I may as well check it before it becomes an issue.
Thanks.
