2018 Heritage wheels
Old Aug 31, 2017 | 10:08 AM
BiKenG's Avatar
BiKenG
Originally Posted by Tom84FXST
Everybody and their brother has come out with tubeless spoke wheels in the last few years...there are company's that will convert any spoke wheel to tubeless.
http://www.motorcyclecruiser.com/sea...tubeless-tires
As I said, the problem with converting tubed type rims is that however well you seal the spoke holes, you will never have the correct rim profile to suit the tubeless tyre.
I'm not scaremongering or even saying don't do it. It is of course up to the individual. Just be aware though of the real implications.
Old Aug 31, 2017 | 11:08 AM
rideflhr's Avatar
rideflhr
When I bought my Deluxe in "12 ,I payed quite a bit extra for the dealer to install:Chromed ,Aluminum,spoked,tubeless,rims. I love 'em.They still look like new and almost never need air. 26,000 mi.
Tubes are ****.they quit using them on cars over 50 yrs ago.
These wheels are "PROFILE" not low profile.
Old Aug 31, 2017 | 12:44 PM
Another Old Timer's Avatar
Another Old Timer
Wonder if the Cast Tubeless wheels off a Road King will fit on the '18 Heritage? Also wonder if Dual front Discs will fit..............???
Old Aug 31, 2017 | 12:52 PM
fireman031967's Avatar
fireman031967
I have the "tubeless" rims on my 2012 Heritage, they do require a "seal" kit that looks like a 3'4" wide black rubber band that is stretched over the rim and is utilized to seal the spokes.
fireman031967
3'4" wide that is
Old Aug 31, 2017 | 12:53 PM
fireman031967
3-4" dammit
Uncle G.'s Avatar
Uncle G.
Yeah, those are the wheels everyone is thinking of, but I don't see them being offered as an option this year.
Old Jan 7, 2018 | 12:58 AM
Twinrider's Avatar
Twinrider
Originally Posted by BiKenG
H-D aren't being cheap here. It is impossible to make a traditional spoked wheel tubeless. The Triumph, BMW and also Honda that have tubeless spoked rims do so by having the spokes attach to the rim OUTSIDE the tyre bead, i.e. on the very edge of the rim and NO manufacturer does that for anything other than adventure style bikes.
KTM's 1090/1190/1290 adventure bikes all come stock with tubeless spoke wheels that are sealed with a rubber gasket.
Old Jan 7, 2018 | 03:48 AM
BiKenG's Avatar
BiKenG
Yup, you're right. It seems sealing a spoked rim for tubeless usage is now sufficiently reliable that manufacturers are actually using it for production bikes. That's a good thing.
I'd be interested in finding out the details of exactly how KTM do this. The aftermarket 'kits' seem to involve permanently sticking a sealing tape to the rim which makes adjusting or especially changing spokes tricky. I would think KTM must employ a better method, to allow spoke replacement etc and maintain (or simply re-apply) the seal.
However it must still be remembered that the tubeless rim profile is different and however a manufacturer seals the rim, it really should be a tubeless rim profile if tubeless tyres are used. Otherwise loss of air can allow the tyre to roll off the rim entirely, whereas a proper tubeless rim will still hold the tyre even with no air in it. Hence why tubeless tyres are so much safer.
Since it is apparently now possible to effectively seal a spoked rim, in production, it is surprising that so many manufacturers don't do this and instead simply fit a tube. I can think of Triumphs and Ducatis like this and there are no doubt others.
Old Jan 7, 2018 | 09:26 AM
T^2's Avatar
T^2
I thought I read around here that Harley offered tubeless spoked rims only for a few years. Thought they were problematic and HD ended their use.
Don't know... Perhaps memory doesn't serve in this case...
