Fatboy Clearance :(
Old Sep 6, 2017 | 11:54 PM
Kaine Dodds's Avatar
Kaine Dodds
1st Gear
Default Fatboy Clearance :(
Hey evreyone im looking at getting a new harley and im stuck in a hard place... my riding is pretty aggressive and would prob suit a fat bob but Look wise im not a big fan and the fatboy is what my heart is set on. Can you make a few mods to the fat boy to get the clearance a bit better for twisties???? I know the fatboy is made to have a nice cruze but surely there are fatboy owners out there that ride aggressively on there fat boy time to time???
Old Sep 6, 2017 | 11:57 PM
JesseDyna's Avatar
JesseDyna
FXSTC with boards. Done :-)
Knock wood - haven't scraped once with boards and I'm on the aggressive side but nowhere near some of the people here.
The thin 21 front tire blows but not that much.
Old Sep 7, 2017 | 02:17 AM
Prot's Avatar
Prot
The new Fat Boy has tires so wide that riding twisters is going to be a chore. The front tire is wider than many bike's back tire and Tye rear is like a steam roller.
That being said, any bike can be modified. It just depends on how much time, money, and effort you want to put into it.
If you are looking at 2018's, the Fat Bob and Low Rider are probably more suited to your needs. If you aren't a big guy, a Sportster might not be a bad choice either.
Old Sep 7, 2017 | 02:41 AM
Kaine Dodds
1st Gear
So i will add that when I mean new harley im looking at the 103 models. Im aware of harleys options but just wanting to know if you can easily modify pegs etc so you can get more of a lean on it
Old Sep 7, 2017 | 03:15 AM
FLSSBart's Avatar
FLSSBart
If the fatboy is your choice or only option you'll need to adjust your thinking and riding style. Even if you choose narrower boards or convert to pegs, you aren't going to get a lot more lean angle. I'm a former road racer and also own a Ducati along with my FLSS. I also live at the base of the Rockies so most of my rides involves twisties.
I can drag boards on my FLSS around just about every corner if I sit straight up. But if I use a bit of my body to shift my weight to the inside of the turn I can go around almost any curve 10-15 mph over and not scrape.
I have a buddy who scrapes his Fatboy S in every corner and it's because he corners his bike like a dirt bike; he pushes the bike into the corners while staying upright...
So I think you can get that little extra clearance with a riding style adjustment, but after that you're still dragging boards maybe you need to consider a different type of motorcycle...
Old Sep 7, 2017 | 07:14 AM
GRWHD's Avatar
GRWHD
I drag boards on all my HD's except my 90 (it didn't have boards).
The Ultra was the scariest ..... at first then there was that corner at on the way back from Idaho.....
My new 17 Deluxe (going in for her 1000 mile check up tomorrow) has had both board scuffed on the bottom (more than once).
It's kinda like a curb feeler, "ok your getting close" time to pay attention.
You just have to get to know the bike
Ow ya the boards fold up nice
If you like to corner I would stay away for extended bags though.
Old Sep 7, 2017 | 07:34 AM
Prot's Avatar
Prot
When I first bought my Heritage I couldn't turn at an intersection without scraping the floorboards. Going to Works Performance Shocks and raising the ride height a little made a huge difference and I rarely scrape anymore.
Since you aren't looking at 2018's but still want a newish twin cam, then I think you should look for a Superglide.
The Low Rider S is also a popular choice with the larger engine, dual discs, and blacked out look along with mid controls.
Old Sep 7, 2017 | 01:46 PM
Thingfish's Avatar
Thingfish
Excellent info and suggestion. Skills worth developing for every rider. Many have no idea why racers stick out their knee on the inside of turns, and it could save your bacon in a tight spot or decreasing radius turn.
Old Sep 7, 2017 | 04:01 PM
wachuko's Avatar
wachuko
Just curious... Since you are buying new... why not consider one of the 2018 Softails? They have improve cornering capabilities when compared to previous years...
Old Sep 8, 2017 | 08:05 AM
Freak Show's Avatar
Freak Show
you could try one of these. because most harley's are made for cruising and not doing the twisties, unless you're a reallly good rider who wants to do some crazy stunt riding on and older dyna
Attached Thumbnails Fatboy Clearance :(-yamaha-xsr-900-by-liberty-yam-02.jpg
johnl111
Mar 15, 2016 04:40 PM
ILMFBL
Jul 1, 2014 12:49 PM
icehead
Jul 26, 2009 09:57 AM
von Wolffe
Mar 17, 2009 02:17 PM
FatBoy4Ben
May 17, 2006 08:14 PM
