custom length fuel lines?
Old Sep 23, 2017 | 11:50 PM
travalab's Avatar
travalab
Default custom length fuel lines?
Where can I find custom length EFI fuel lines with the connectors already installed? With the new tank on my bike I couldn't make the stock one work.
Any ideas?
Thanks!
Old Sep 25, 2017 | 08:02 PM
mac1313's Avatar
mac1313
Any ideas?
Thanks!
I cut the fittings out of the factory fuel line and installed them on a longer fuel line on my RSD tank because I had the same problem.
Old Sep 26, 2017 | 06:29 PM
travalab's Avatar
travalab
I found out that the Dyna fuel line is almost 2 inches longer than the Softail one. It was just long enough to make it around the coil mount and to the petcock.
I wish I could find a straight quick disconnect valve rather than the HD L type valve, then I could run the line straight down and under the coil bracket, assuming I could adjust the nipple on the throttle body. The way I have it now it goes towards the rear of the bike and then twists and comes forward to connect to the nipple on the throttle body.
Do you have a photo of how you ran your fuel line?
Old Sep 29, 2017 | 03:50 AM
j33ptj's Avatar
j33ptj
Does the Dyna fuel line have the same connectors as the Softail?
thanks
RJ
Old Oct 16, 2017 | 11:18 AM
travalab's Avatar
travalab
thanks
RJ
Yes, same connectors.
DanDman
Jun 3, 2013 06:30 PM
fatboy1729
Apr 18, 2013 06:31 AM
kjelders
Jun 22, 2012 03:43 PM
cacolade
Mar 23, 2012 09:14 PM
rbabos
Dec 6, 2008 12:46 PM
