Hard start
Old Nov 14, 2017 | 06:34 PM
ktrsek's Avatar
ktrsek
Stage IV
Default Hard start
2009 Fatboy. Sometimes it fires right up. Sometimes there's a screeching/grinding noise and engine fails to start. Subsequent attempts sometimes go ok and engine starts, but just as often repeats the screeching noise. Does this sound like it could be the starter not engaging fully or intermittently?
Old Nov 14, 2017 | 06:48 PM
SDozier's Avatar
SDozier
Neighbors bike (07 Softail Custom) does the same. He has been told by an individual mechanic it likely is the compensator going bad. He has not repaired it (in progress) so I cannot say that is what is wrong. You may wish to research what effect a bad compensator has. SUP
Old Nov 14, 2017 | 07:37 PM
kb_jag's Avatar
kb_jag
Just curious , is the engine stock , or has the displacement been increased ?
Old Nov 14, 2017 | 07:38 PM
ktrsek's Avatar
ktrsek
Stage IV
Thanks- will do. keep me posted should your neighbor successfully fix his.
Old Nov 14, 2017 | 07:49 PM
ktrsek's Avatar
ktrsek
Stage IV
Stock 96 cu in. Screaming Eagle.
Old Nov 16, 2017 | 09:52 AM
kb_jag's Avatar
kb_jag
Thank you. I asked because we saw the compensator issue a bit on the big bore upgrade kits without compression release. On a stock 96. Not so much. Hard to speculate but yes the compensator would not be the worst place to start looking.
Old Nov 16, 2017 | 12:59 PM
ktrsek's Avatar
ktrsek
Stage IV
Subsequent cold starts have been fine. Symptoms seem to point to the compensator. Pretty much done riding until spring- lots of time to sort it out. Thanks for your input.
Old Nov 16, 2017 | 06:48 PM
heybaylor's Avatar
heybaylor
welcome to Harley starter design.
search the threads about compensators, and starter clutches.
and if you have never pulled a soft tail starter , then plan all day to do it
Old Nov 16, 2017 | 08:06 PM
08fxdf43202's Avatar
08fxdf43202
My 08 FXDF did the same thing.... it was a bad starter clutch.
BorJan
Apr 3, 2015 09:11 AM
J-Dog
Nov 2, 2012 10:59 AM
Purplesky
Oct 5, 2012 05:32 PM
nealhix
Apr 19, 2012 02:40 PM
kenaaby
Exhaust System Topics
Oct 19, 2009 11:12 AM
