Harbor Freight jack
Old Jan 10, 2018 | 08:26 PM
ktp1598's Avatar
ktp1598
Got it for $76. It's the cheap one though. They have at least 2 styles.
Old Jan 11, 2018 | 07:04 AM
GRWHD's Avatar
GRWHD
Be careful of the handle.
Mine is a tight fit under my 17 Deluxe, but it fits.
My wife broke the weld that holds the tube the handle slides into.
So I will have to re-weld it (didn't take much).
Old Jan 11, 2018 | 07:19 AM
Iceman24's Avatar
Iceman24
Originally Posted by 67Shuv
The HF lift is on sale right now for $299 I believe.
That's the "lift" vs. the jack which pretty much runs ~$80...
If anyone's looking for a good buy on the lift...the $299 sale is a good deal tho.
Old Jan 12, 2018 | 06:11 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I purchased one a couple of months ago and after assembling it, it would not go down all the way. Someone welded the the perch for the top of the hydraulic jack to low. No matter what I did it would not go down all the way. I brought it back.. real cheap crap.... You get what you pay for..
Old Jan 12, 2018 | 07:12 PM
irydasteelhorse's Avatar
irydasteelhorse
ive had mine for about 3 years now and done TONS of work with it. never let me down, no problems other than having to re-glue the rubber strips on the lift legs. hell, ive used it to jack up several cars too, including my musclecar.
one of my best harbor freight buys.
Old Jan 12, 2018 | 09:20 PM
ktp1598's Avatar
ktp1598
You do get what you pay for but sometimes you get lucky.
Old Jan 13, 2018 | 12:44 PM
harleyrider4300's Avatar
harleyrider4300
I am the op. I took my hf jack back this am as lifting arms were not parallel. Swapped it for another one and put it together. Won’t go under the sporty 1200C. I will pick up a couple of pieces of 3/4 plywood to put under the wheels. I only need about an 1/8 of an inch and the jack will clear then. Is that what most of users do. My bike is not lowered.
Old Jan 13, 2018 | 01:09 PM
BikerPepe`'s Avatar
BikerPepe`
Mine's not HF but I have to pull the bike upright to slip under the furthest frame point from entry. It's not a big deal to hold it upright with one hand while I jack it up snug to the fame with my foot.
I've also had to re-glue the rubber pads but this one has lasted me over 20 years and gone through a few bikes.
Old Jan 13, 2018 | 01:15 PM
Vinman411's Avatar
Vinman411
I just got the craftsman yellow super low one for $160 on sale, that thing goes under my cv0 breakout with ease
Old Jan 13, 2018 | 01:35 PM
Bluraven's Avatar
Bluraven
+1 for the yellow jack.
It drops to 4" which is one of the low enough to fit under my Heritage.
Plus it's light enough to hang on the wall.
HF sells a similar one that I think is the same manufacturer.
With the 20% off coupon the HF one is only about $136.
https://www.harborfreight.com/1500-l...ift-63397.html
