Battery issue
Old Jan 18, 2018 | 08:06 PM
Dave0176's Avatar
Dave0176
Default Battery issue
I seem to be having an issue with my new as of July HD battery. My HD 750 MA charger is connected constantly, however for the last month, all I’m getting is a alternating yellow green flashing light. The manual says this is due to sulfated battery?? Really the battery is brand new??
Bike is 2009 FXSTC
Old Jan 18, 2018 | 08:23 PM
MURPHCC1's Avatar
MURPHCC1
I bet the tender is bad........return it!
Old Jan 18, 2018 | 08:30 PM
hattitude's Avatar
hattitude
My Deltran Battery Tenders usually last 7-10 years of constant use, but I have had two go bad in a short period of time (I dropped one on concrete so that probably shouldn't count).
My batteries usually last 4+ years, but I've had a couple go bad in short order...
I'd test the battery. If it tests OK, I'd replace the battery tender.
Old Jan 18, 2018 | 08:44 PM
TeaRunner's Avatar
TeaRunner
I've had two HD batteries go out in less than six months each. They're junk.
Go to an auto parts store. The battery will have a date on it, cost at least 1/3 less, and have a warranty.
I think most of those HD batteries have been sitting on the shelf for a couple years.
Old Jan 18, 2018 | 09:07 PM
Bone Doc's Avatar
Bone Doc
There are three possibilities:
1. The battery tender is bad
2. The battery is bad
3. The battery is sulfated
Actually, the battery is not brand new. It's been sitting on Harley's shelf for an unknown length of time and you've had it for seven months. Maybe it is sulfated. Do you have a battery charger with desulfation mode?
If yes, desulfate the battery and see if the situation changes. If not, the cheapest solution may be to return the battery to HD for another new one. It is under warranty. If there is still no change then I would buy a new battery tender.
Good luck.
Old Jan 18, 2018 | 10:32 PM
J F GO's Avatar
J F GO
Take the Tender in and have it checked to see if it is working properly. Have your battery checked to see if its taking a charge and holding a charge. Most Batteries Plus stores will do that for you and I've never been charged anything for that service either.
Old Jan 18, 2018 | 11:25 PM
nvbirdman's Avatar
nvbirdman
Can you check the tender by simply hooking it up to your car battery?
Old Jan 19, 2018 | 06:20 AM
Dave0176's Avatar
Dave0176
Funny you mention that, I connected the charger to my Sportster and got the same situation.
Old Jan 19, 2018 | 09:06 AM
Hammz's Avatar
Hammz
Two bikes, same charger, same results? So what's the common link? Probably not the wall outlet?
Old Jan 19, 2018 | 09:50 AM
chrisj49's Avatar
chrisj49
Harley batteries are warrantied. If they both went out in 6 months they were both under warranty.
Harley batteries are made by Deka. You can get the same battery at O'Reilley.
In summary:
Not junk
Warrantied.
Cheaper to buy the one without the Harley branding on it.
