Ordered a PM front 6p and 4p rear for 07 fatboy
Old Jun 18, 2007 | 05:23 PM
vertigo14's Avatar
vertigo14
Default Ordered a PM front 6p and 4p rear for 07 fatboy
Ordered a 6piston front PM brake for the front and a 4piston PM brake for the rear..
talk about money LOL, next day air 40bucks
cost around a grand LOL (CRY)
Ill put some pics on this tomorrow when I slap them on
everyone is like 2-3 weeks out for a rear caliper including Harley Davidson.. wtf LOL except HOG-PRO a sponsor here
guess ill get my wheels from them and rotors when I recover since they were f'n cool on the phone with me.
Old Jun 18, 2007 | 05:28 PM
shooter64's Avatar
shooter64
Former Sponsor
Default RE: Ordered a PM front 6p and 4p rear for 07 fatboy
dude, I could have saved you some coin....post some pics....wanna see it when it's done
Old Jun 18, 2007 | 05:31 PM
vertigo14's Avatar
vertigo14
How shooter64 ? how could you save meh some coinage?
I got like 50 off the fronts list price and 40 off the rear price..and 40bucks next day air(tomorrow will be here)
Old Jun 18, 2007 | 07:08 PM
Hammer02's Avatar
Hammer02
I am curious...why upgrade the calipers without doing the wheels?
Not being a wiseass...just curious as to why bother?
Old Jun 18, 2007 | 08:25 PM
vertigo14's Avatar
vertigo14
$$$$ lol one part at a time :P
after these brakes, all i need are the wheels and rotors and a pully (bars, cables, controls, grips going on as soon as they get here this week along with the new brakes tomorrow(at least rear)
so 1500.00 per wheel.. 3k, rotors 1k or so.. and a pully 400.00... got 4500.00 to donate ? oh new tire for front..if going out to an 18 or so..
Old Jun 18, 2007 | 08:33 PM
vertigo14's Avatar
vertigo14
Oh and the dumb *** reason...
I screwed my rear caliper up ;P and the one part thats not serviceable by HD....
anyways I went to a dealer to see if they had the part or the bottom of the brake.. no dice..
and the 175.00 caliper(black) is back ordered for 3 weeks
so why not upgrade
spent time on the phone with Hog Halters and they wont have the rear in for another 2 weeks
and PM brakes are also back ordered on the rear...
so I called around to dealers.. and told HOGPRO the part numbers to PMs rear I need and the Hog Halters and they had the PMs
so i have a ride in less than 2 weeks and a few smaller rides in between so I ordered em to get here asap(tomorrow) heh
Old Jun 20, 2007 | 12:51 AM
wlbowers's Avatar
wlbowers
ORIGINAL: vertigo14
Nice brakes. Friend of mine put them on his V-Rod. Use a Torque wrench to tighten the bolts. The dealer stripped one of his out installing them. He had to helicoil.
Old Jun 20, 2007 | 01:41 AM
vertigo14's Avatar
vertigo14
What bolts.. at least on the rear brake.. there is none......
it goes around the axle and there is a little pinch screw(allen) that grips the little tab on the bottom of the swing arm
it was really simple..
1. remove debris guard, belt guard
2. remove pin, and take axle nutt off (and no you dont have to mess with the belt adjusting bolts..even if the manual says you do)
3. Unloop the belt on the pully...support the wheel then
4. tap out the axle...it isnt very anti-seze coated so it might be a little bitch..
5. roll the tire out of the swing arm
6. loosen the brake wheel (rotor) and slide the PM brake onto the rotor.
7. torque the rotor back on per spec...
8. roll wheel back to the swing arm.
9. coat axle with anti-seze
10. push axle through with respective spacers..
11. push the belt on the pully back on.
12. put the axle nut back on, torque it(have to hold the other side of axle) and put pin back in
13. since you didnt remove the belt adjusters, the belt should be fine
14. hook up your brake line and bleed the brakes..
15. put back ur belt guard and debris guard..
16. go for a ride...
Old Jun 20, 2007 | 02:21 AM
wlbowers's Avatar
wlbowers
Ya got that rear setup down pat.
Now I see you are going to put them on the front. What are you planning on attaching them with? Tyraps.
I was trying to save you some possible grief. Their calipers don't seem to take kindly to over tighting the front caliper mounting bolts.
But i guess it wasn't needed.
Old Jun 20, 2007 | 02:54 AM
vertigo14's Avatar
vertigo14
Hmm some chrome 12 point bolts the same kind as the black 12points in the stock one...
ya torque em to spec.. first about 80% of their torque
then the min torque then about middle of the low and high of the toruqe
each time you need to reset the torque wrench (hah if u know my post history i have a nice story on that one) if its a click wrench
should be very simple... simpler than the rear
