2007 softail starter
Old Feb 12, 2018 | 08:48 PM
Nick Harley's Avatar
Nick Harley
2nd Gear
Default 2007 softail starter
2007 Harley davidson softail deluxe: Is the starter pinion gear and ring gear suppose to be partially in mesh at all times????? I believe the pinion gear should not mesh until the starter is energized.
I replaced the pinion and clutch on the starter already and it seemed to go in fine, but now I noticed the pinion is in mesh with the ring gear.
Old Feb 13, 2018 | 02:34 PM
wadejesu's Avatar
wadejesu
I have a new starter I'm not using if your interested, I'll check part#
Old Feb 13, 2018 | 06:25 PM
Nick Harley
2nd Gear
Thanks Wally! I think I know what went wrong. The new pinion clutch assembly came with a ball already inserted in the bore (cant see in side) I insert the old ball in the bore, so I had two ***** inserted instead of one, guess I should of measured with a caliper. I'll know tomorrow after I install the starter, but I'm thinking I should be OK.
Hardley dave
Oct 11, 2017 03:36 PM
Pinetop
EVO
23
Nov 10, 2015 11:33 AM
rprider
Nov 16, 2012 09:16 AM
Jackie Paper
Dec 15, 2011 01:16 PM
ConRic72
May 15, 2010 09:18 AM
