Help! Primary whistling sound
Old Feb 15, 2018 | 12:48 PM
HDfanatic1985's Avatar
HDfanatic1985
6th Gear
Problem resolved gentlemen! The tensioner is ok. I just had to collapse it ALL the way down to its lowest position. Put it back in and works and sounds great.
I appreciate all the advice gentlemen and I wouldn’t have been able to resolve the issue without yalls help!
HDfanatic1985
6th Gear
Originally Posted by S.D.M.F
I will be looking into getting a better one.
Old Feb 15, 2018 | 02:27 PM
Jackie Paper's Avatar
Jackie Paper
You have the best one made. You do not just want it spring loaded. It needs to lock in and not jump till it gets over 1/4 " slack past 1/2". Then it will jump only one notch.
If it's just spring loaded, it's always tight top and bottom the spring loaded. Harley's manual and your Harley automatic always has play on bottom. Of course top is tight when driving it fwd under load.
molson9
Oct 21, 2017 12:00 AM
Encosi
Jan 16, 2013 09:38 AM
Jethro
EVO
Apr 27, 2012 08:56 PM
turn55
Sep 25, 2006 12:48 PM
HDF Tech
Jun 25, 2005 11:31 AM
