Primary
Old Feb 26, 2018 | 07:40 PM
Joel282's Avatar
Joel282
Default Primary
01 Fatboy, 18k mikes. Primary gasket started leaking the other day. It's original. I purchased a replacement. Each time I've changed the primary oil I've used approx 24-26oz of primary fluid. When opening the primary to change the gasket and it emptying completely, how much primary oil should I need? I want to make sure I order the right amount (in case I'll need any from a second quart)
thanks!
Old Feb 27, 2018 | 03:08 AM
S.D.M.F's Avatar
S.D.M.F
I usually drain it, and fill it with 1 full quart.
Never had any issues.
Old Feb 27, 2018 | 10:36 AM
hattitude's Avatar
hattitude
Different bikes with different size primaries will dictate the amount.... check with the service manual for your year bike... OR....
Just put in the usual amount, an then, with the bike standing up, off the jiffy stand, fill it up to the bottom of the clutch pack..
NOTE- my 88ci softail service manual says 26oz... the difference between drain/refill and cover-off refill is usually 4 to 6ozdepending on the size of the primary...... you should be fine with buying 1 quart.. Of course, never hurts to have a spare on hand...
Old Feb 27, 2018 | 10:44 AM
Tampa Fatboy's Avatar
Tampa Fatboy
No manual? Primary fluid - 96ci takes 1 quart, 88ci takes 26 oz. Please, double check me tho.
Glideride78
Jan 14, 2017 11:34 PM
JONNIEROCK
Sep 2, 2016 08:33 PM
ROADKING861
Feb 6, 2012 04:14 PM
mike33ca
May 26, 2010 01:26 PM
OneBlackFly
Oil Archive (no new posts)
Apr 3, 2006 12:59 AM
