clutch adjustment went wrong
Old Mar 15, 2018 | 01:25 PM
mdavis44's Avatar
mdavis44
Stage III
Default clutch adjustment went wrong
2001 fat boy changed left rod because it was stripped at the ale end replaced new when I was turning it to adjust when I heard popping noise now it wont engage the cluth basket moves when I pull lever but wont engage everything seems to work tho. my clutch cable is old could that be it how many thing s can it be worked great until I tried o adjust it.so question is how many things did I mess up and how many things can it be
Old Mar 15, 2018 | 01:34 PM
Tom84FXST's Avatar
Tom84FXST
Old Mar 15, 2018 | 01:36 PM
Bluraven's Avatar
Bluraven
I'll have to be honest with you; I can't follow your description of your problem.
The clutch adjustment is a pretty simple process.
Just follow the procedure in the service manual.
If you don't have a service manual then you need to get one.
Also, there are numerous youtube videos on clutch adjustments.
Perhaps one of those will help you.
As for the cable; if it's old then order a new one.
They are not that expensive and you don't want to be on the road when once breaks.
Old Mar 15, 2018 | 02:33 PM
izzyryder's Avatar
izzyryder
I'll Try!
2001 fat boy. changed left rod because it was stripped at the ale end. replaced new. I was turning it to adjust when I heard popping noise. now it wont engage. the cluth basket moves when I pull lever but wont engage. everything seems to work tho. my clutch cable is old. could that be it? how many thing s can it be?? worked great until I tried o adjust it.so question is, how many things did I mess up? and how many things can it be?
Old Mar 15, 2018 | 02:35 PM
izzyryder's Avatar
izzyryder
Just a guess but sounds like you didn't properly adjust the clutch. I would re-do it.
Old Mar 15, 2018 | 03:34 PM
mdavis44's Avatar
mdavis44
Stage III
Default thxs
I know it sounds simple and believe me I have tried many
adjustment, seems not to be the problem. ihave a new clutch cable coming,what I want to know is why was there a popping news when I tighten the left rod inand could ihave damaged any part of clutch
Old Mar 15, 2018 | 03:44 PM
mdavis44's Avatar
mdavis44
Stage III
Default thxs
thxs but iwas bad at explaining when I was putting new left rod and nut I think I screwed it in to far cause there was popping noise.any part of clutcht could be messed up and did I damaged it I have a new cable coming but don't think it is that.have tried many more adjustments seems tobe ok till I try to use clutch wontwork
Old Mar 16, 2018 | 01:21 PM
Daggett's Avatar
Daggett
nice cartoon fella, made me laugh out loud.
Old Mar 16, 2018 | 03:44 PM
fat daddy's Avatar
fat daddy
Pm me I live in New Port Richey and I could come over and give you a hand
jamala00
Aug 30, 2012 03:25 PM
skydude426
Jun 9, 2012 07:36 AM
FFHD05
Aug 28, 2011 06:09 PM
martinspencer
Jul 24, 2010 08:47 AM
KYFATBOB
Mar 2, 2010 08:23 PM
