Fuel Pac program after battery change
Old Apr 3, 2018 | 11:44 PM
balloo's Avatar
balloo
Default Fuel Pac program after battery change
I am getting ready to change the battery in my 2008 Heritage, which has the V&H fuel pac.
I was told that the Fuel Pac will need to be re-programed after the battery has been disconnected.
Does anybody know if this is correct?
Thanks,
Old Apr 4, 2018 | 06:26 AM
Bluraven's Avatar
Bluraven
My FP1 hasn't needed to be reprogrammed, but then again I've not looked at it since it was installed and I've gone through 2 battery changes since.
The bike runs the same as always so I assume the FP1 retains it settings.
But even if it has to be reprogrammed; it is what it is.
Change the battery and if needs to be reprogrammed then reprogram it.
Old Apr 4, 2018 | 07:50 AM
elPrez's Avatar
elPrez
Crap I hope not! I have had the dynojet system through 3 batteries and never thought about it losing the program...
Old Apr 4, 2018 | 09:08 AM
jkinner's Avatar
jkinner
Email Vance and Hines customer service, get a straight answer, vanceandhines.com
Ride safe
Old Apr 4, 2018 | 09:10 AM
chrisj49's Avatar
chrisj49
Thanks,
You won't lose the map when you change the battery. They use the same kind of memory that is used to store photos on your cell phone - it gets programmed and stays that way until it gets erased or overwritten.
Old Apr 4, 2018 | 09:28 PM
Dukes_Slim's Avatar
Dukes_Slim
2nd Gear
The FP3 won't be affected by changing the battery on the bike. As indicated, it uses E2Ram to store all the maps, likewise the bikes VIN number when first connected and it is assigned. Also consider this if you are still worried. You can unplug the FP3 from the bike computer if you don't want it connected all the time and it doesn't loose it information. No difference, however if you are still concerned, about a battery change doing something different, unplug it before you disconnect the battery.
Old Apr 4, 2018 | 11:57 PM
balloo's Avatar
balloo
Thanks,
THANK YOU EVERYONE FOR THE INFORMATION....SOUNDS LIKE I AM GOOD TO GO.
Balloo
Dirty Camo Girl
Oct 19, 2017 10:36 AM
bluemsp4
Dec 19, 2014 07:40 PM
falsealarm
Mar 16, 2013 10:21 AM
sammer4u
Jan 4, 2013 05:48 PM
swbob
Jul 27, 2012 01:16 AM
