alarm pin code
Old Apr 25, 2018 | 07:52 AM
randymansd's Avatar
randymansd
Stage II
Default alarm pin code
2006 Sportster 1200 custom cant find fob, bike wont start, nada when hit start button. Battery good, run switch good, fuses good, new relay. Alarm icon not lit, but maybe I need to make sure that isn't the problem
Old Apr 25, 2018 | 04:32 PM
Bluraven's Avatar
Bluraven
Well first this is the Softail forum.
However if your bike's got Harley security and you don't have the fob or the code then you'll need to push it to the dealer to have it unlocked.
Make sure you bring proof of ownership.
Old Apr 25, 2018 | 06:18 PM
Bone Doc's Avatar
Bone Doc
At 4 am you posted this thread in the Sportster forum...
Originally Posted by randymansd
it wont start, it wont click. Battery is good. Changed out carburetor, started bike, let is warm up. Shut it down; went to restart got a click, blew a fuse, changed fuse, got new relay, not nada. Lights go on with ignition.
tried DVOM Poss.lead to battery pos. ground lead to solenoid, 12.6 volts. What is open? change solenoids//////////////
At 7 am you posted this here in the Softail forum...
What changed between the time the bike started and the bike didn't start? If you didn't have the FOB when the bike started then it isn't the security system.
Old Apr 25, 2018 | 06:21 PM
Iceman24's Avatar
Iceman24
Another problem child welcome & ditch.
OP; Does your bike have security FOB, or not? If it does...find the FOB. If you don't know the security PIN, you're f'd.
Nathalie
Jun 6, 2017 03:28 AM
CrossBones79
Apr 28, 2015 07:40 PM
predatornut
Mar 22, 2015 04:31 PM
ghoticov
Apr 27, 2013 05:11 PM
sedouglas
Jan 1, 2012 02:31 PM
