05 & 07 Swingarm Differences?
Old Jun 24, 2007 | 03:53 PM
Dr.'s Avatar
Dr.
Stage III
Default 05 & 07 Swingarm Differences?
Does any one know what the demensional differences are between the 2007 and 2005 Fatboy swingarms?
Doc
Old Jun 24, 2007 | 06:00 PM
DaveJ's Avatar
DaveJ
Default RE: 05 & 07 Swingarm Differences?
I did a thorough comparison of the swingarms on an '04 springer and my '06 Standard(well, as thorough as it could be with them still attached to the bikes). They are the same swingarms as the old/new fatboys, and the dimensions are the same. The only difference I could find was the tab the brake caliper mounts to.
I am going to go out on a limb and guess you want to put a 200mm tire on. Someone submitted a post a while back stating they were able to convert their ('00-'05) Softail using the original swingarm and brakes. If I recall, they only had to change the pulley, belt, and wheel. But I don't remember.
[align=left] [/align]
Old Jun 24, 2007 | 09:05 PM
Dr.'s Avatar
Dr.
Stage III
Thanks, you are correct, 200m tire. Your research makes sense. However, they have different stock HD part numbers and your data is a year short. In supporting you I know for a fact from axel bolt frame, ear to ear, is the same.
Thanks again,
still seeking
Old Jun 24, 2007 | 10:10 PM
DaveJ's Avatar
DaveJ
I am not sure I understand your response. Yes, the part numbers are different, but from what I gather it is due to the different brake caliper mounting tab. I don't have the means to look up the stock part numbers right now, but if you look at the part numbers for chrome swingarms on HD's website, you will see there are 2 flavors:
'00-later Softail models (except '06-later FXST, FXSTB, FXSTS, '06 FLSTFSE2 and '07 FLSTF and FXSTC).
-and-
'06-later FXST, FXSTB, FXSTS and '07 FXSTC and FLSTF models.
This would tell me the two swingarms I compared would be relevant to this discussion. The only difference I know between the '06's and '07's would be the wheel. I have read here on HDForums they switched to metric axel's on the '07's.
Hope that helps.
Old Jun 25, 2007 | 08:17 AM
back again's Avatar
back again
Dr. check out Chops fat tire thread. It's near the top off the page now.
I8AGSXR
Feb 7, 2012 03:37 PM
krstrahm
Mar 21, 2008 01:03 PM
Vrod Blk Chry
VRSC Models
Jul 13, 2007 08:18 PM
ozynet
May 5, 2007 10:38 PM
Glen1978
Mar 5, 2007 11:13 AM
