I have a 2002 Heritage Softail Classic(In signature pic below). I had a RevTech 6 Speed gear set installed and ever since, shifting into first is interesting seems it grinds a bit then you have to push it into gear quick. Second gear is really hard. After it warms up it is a little better. I have checked and adjusted the clutch cable...clutch..primary. Still is an issue. I had a falling out with the guy that installed it so I can't take it back to him. Was wondering if anyone could give any advice on what to do next before taking it to a shop? I thought maybe adjusting the shift linkage rod or pawl adjustment? To get to the pawl I have to take the starter out. I appreciate any advice, thanks.
Not to be mean - but its a revtech, they`re cheap all around, they will last long enough to cause you problems. I don't blame you for wanting a 6 speed Im always wanting to shift mine from 5 to 6 & dam.....not there! ive been into a few of those & the tolerances are not very good (very sloppy) did you inspect the gear cluster before install? ive seen them with machining burrs, the gear lash can be tight here & lose there, you are probably noticing that the higher gears are smoother than 1 & 2?
easy bandaid = drain fluid - check magnet for shavings & put in a good fluid & see how that does, if really bad = you may have no choice but to go internal & check it out. Good luck!
I appreciate the response. Not a big RevTech fan either but he recommended them. He has a set in his bike which he has thousands of miles on. I've read good and bad on RevTech. It's hit and miss. I debated on even posting the question because it is a RevTech gearset but long story short I have money in it now so just trying to get it right. And because he took the gearset out of the trans he ordered, I have no warranty. I know I could take him to court or just stomp him but neither would get my money back (He stays broke).I don't know much about the internals. I did adjust the clutch...clutch cable...and when I checked the primary again it was a bit tight. Rotated it around to find the tightest spot and set it right. Took it down the road again and it's changing like it should at the moment. The gears do feel a bit sloppy to me. 6th is a little noisey I noticed. I can probably run some heavier fluid in the gearbox and hopefully clear some of that up. 1 & 2 are okay. 3 shifts a little hard. The rest going into gear fine. Any certain fluid you recommend ? I've heard Amsoil 20/50...Redline Heavy w/Shockproof...etc. He said he has "Break-in" fluid in it that you keep in for 1000 miles then change it out. I'm hoping at this point it makes it 1000 miles.
Try putting in AMSOIL gear oil 75W110.
I can across a great deal on some off craigslist and will never use anything else.
Other than the traditional "clunk" noise when going into 1st I had no issues.
However the gear oil quiet that down a lot as well as it seems to make my shifting smoother.
