Rear brakes started locking
Old Jul 21, 2018 | 07:03 PM
oakfan71's Avatar
oakfan71
Stage III
Default Rear brakes started locking
Hello,
I have a 2004 Softail. Suddenly my rear brakes started locking up when they haven't even been used. After I sit for several minutes they release. Then the process starts all over again.
I had the break lines changed after this started, still does it. Could it be the caliper or master cylinder?
Old Jul 21, 2018 | 08:36 PM
badcooky's Avatar
badcooky
The caliper needs maintenance , the pistons are jamming.
More than likely .
Old Jul 21, 2018 | 08:47 PM
oakfan71's Avatar
oakfan71
Stage III
More than likely .
Even though it happens when the brakes haven't been touched? Caliper was my guess, but I've been reading about the master cylinder
Old Jul 21, 2018 | 08:53 PM
TwiZted Biker's Avatar
TwiZted Biker
Take a wrench for the bleed port with you, when the rear locks up again break the bleeder port a hair. You get a good spurt there's air in the system, probably sucking at the MC. Just a little wet it's caliper issues pads expanding as it get hot, could be dirt, bad pads or an alignment issue.
Old Jul 21, 2018 | 08:56 PM
oakfan71's Avatar
oakfan71
Stage III
Ok thanks
Sid1200
Jun 9, 2017 03:21 PM
BACON84
May 16, 2013 09:57 AM
vbhousehunter
Wheels/Tires
Nov 4, 2012 08:31 AM
xMPRx
EVO
Oct 16, 2012 04:17 PM
springerscott
Oct 10, 2007 12:24 PM
