Fairing
Old Aug 1, 2018 | 01:14 PM
kambre5@msn.com's Avatar
kambre5@msn.com
6th Gear
Default Fairing
I recently bought an 08 Heritage Classic that has a fairing, 4 speaker style. How do I know what brand it is? I am wanting to put a smoked windshield on it. Will any windshield work?
Old Aug 1, 2018 | 02:00 PM
Sixgunjr's Avatar
Sixgunjr
Picture of the windshield off the bike would help. Most of the after market fairings have harley windshields.
Old Aug 1, 2018 | 03:35 PM
Bluraven's Avatar
Bluraven
If it's a "Reckless Motorcycle" fairing there should be/was a "RM" badge about the size of a quarter on the right side of the fairing.
Also, if the distance between the center bolt and the outer bolt is around 10 1/4" then it's likely an "ultra" 1996-2013 shield.
https://longrideshields.com/collecti...=1552451371017
Old Aug 1, 2018 | 03:38 PM
kambre5@msn.com
6th Gear
Ok ty. I will look this evening
Old Aug 1, 2018 | 07:16 PM
kambre5@msn.com
6th Gear
Well no RM. But it was 10 1/4
Old Aug 2, 2018 | 07:31 AM
GRWHD's Avatar
GRWHD
Mine is a "no name" fairing.
I had the outer shell from my old 01 FLHT to check it against, they were close (but different).
So I contacted LRS (via e-mail) and discussed it, then I ordered a windshield from them.
There initial ETA was past the time I was going on a trip so I ordered a fill in off Amazon.
The one form Amazon I had to modify to get it to fit (open up/slot the outer holes).
Worked fine, then the LRS showed up earlier than initially expected, it fit perfectly (no mods required).
But to know if it curvature & hole pattern match, get your hands on the trim that goes on the outside (of a HD bagger).
That is the cheapest/easiest way I can think of.
My fairing has a little different curvature and the hole pattern is a little wider than HD fairings.
Do you ride with anyone with a Harley bagger?
See if you can borrow there outside windshield trim (or if they have there old one laying around {allot of people change them out}).
Lay it over the top to check curvature and hole pattern.
For my outside trim I ordered one that would fit a Harley bagger that was made of thin aluminum.
When it came I adjusted the curvature and took a rat tail file and opened up the otter holes so it would fit (did not take long and you can't tell as the screws cover it up).
Old Aug 2, 2018 | 07:37 AM
GRWHD's Avatar
GRWHD
Compared, the black (above pic) is the 01 FLHT.
My cheep adjusted trim
Old Aug 2, 2018 | 07:45 AM
kambre5@msn.com
6th Gear
Ok. Thanks
rsmith
May 4, 2015 09:01 PM
Teardrop
Aug 4, 2013 01:58 PM
AngryEchoSix
May 16, 2013 10:43 AM
harlynoob
Jan 3, 2013 01:44 PM
JC650
Jul 17, 2007 12:36 AM
