Caberator problems
Old Aug 6, 2018 | 08:21 PM
CBurch's Avatar
CBurch
1st Gear
Default Caberator problems
I finally upgraded my cam plate and while in there I replaced my cam with SE204. I had 72 main jet and 29 inter with stock cams. So with the new ones I went with 74 main and 31 inter I keep getting popping out of the exhaust like it was to lean. So I went up to the 76 main and it got worse so I went back to a 72 and it got better but still some popping so I changed my inter back to a 29 and not much change. It pops about half throttle around 35mph and then around 80mph. If you go from a dead stop to wide open no problems. I tested like S&S says on their website 3rd gear running 50-70 and it runs fine in that area. Any help would be appreciated!!
Old Aug 6, 2018 | 08:28 PM
misfitJason's Avatar
misfitJason
Have you made any adjustments or are you just swapping jets. Does your super e have a removable air bleed?
Old Aug 7, 2018 | 07:51 AM
CBurch's Avatar
CBurch
1st Gear
Yes I have adjusted the accelerator pump and air mixture. I am sure I have those where it should be. Yes it does have a air bleed jet.
acm5708
Aug 11, 2019 07:32 AM
Eyolv Holm
Engine Mechanical Topics
May 31, 2019 02:28 PM
Peterbuchberg
25
Oct 22, 2018 05:09 AM
Brink481
Mar 22, 2018 01:15 PM
twowheelsforever
Exhaust System Topics
16
May 3, 2007 12:09 AM
