Engine dies when given gas.
Old Aug 8, 2018 | 08:25 PM
Ted503's Avatar
Ted503
Stage II
Default Engine dies when given gas.
I have a 94 Heritage Softail, It will start and run with choke on but as soon as I give it gas it dies. I've let it warm up at the idle and still the same problem.
Old Aug 8, 2018 | 08:29 PM
mmesa005's Avatar
mmesa005
Could be the carburetor, intake manifold seals? Do you know when the last time the carb was cleaned, float level checked?
Old Aug 8, 2018 | 08:45 PM
Ted503's Avatar
Ted503
Stage II
I just flushed the tank, changed the filter and let clean gas run through the carb. The bike hasn't been run since last summer.
Old Aug 8, 2018 | 08:54 PM
mmesa005's Avatar
mmesa005
Leads me to believe your carb is in need of cleaning.
Old Aug 8, 2018 | 09:07 PM
RANGER73's Avatar
RANGER73
Could be the float or clogged jet. Run some carb cleaner or Seafoam through it.Drop the float bowl and blow it out with canned air.
Old Aug 9, 2018 | 01:05 PM
o/d's Avatar
o/d
remove carburetor, compressed air thru all passages. check, clean & or replace jets and o-rings as needed is what i'd do if it were my bike
Old Aug 9, 2018 | 02:31 PM
Riffraff123's Avatar
Riffraff123
Josepek
Aug 17, 2013 11:36 AM
John7253
Exhaust System Topics
Jun 13, 2012 10:48 PM
JohnFlorida
Apr 26, 2011 02:33 PM
Doughboy
Apr 24, 2009 10:01 PM
zenwarrior
May 12, 2006 09:37 PM
