Headlight Mount on Springer
Old Aug 9, 2018 | 05:25 PM
hattitude's Avatar
hattitude
Originally Posted by 4 inch pistons
If what happened to his is the same thing that happened to mine, that will not help. Inside the bucket is a thick rubber disc with threaded bolts coming out of both sides, but the bolts are not one in the same--they are 2 separate studs but designed to reduce the vibration but at the same time connect the inner housing to the bucket (If I remember correctly-it has been a while) I just replaced the whole thing with a single bole with thick rubber grommets between the 2 surfaces to give it some vibration dampening and a solid mount. Hard to explain, but not hard to fix with a little imagination.
AGAIN, I am assuming we experienced the same problem.
Thanks......
I have an '01 FXSTS, but never needed to open or take off the headlight. It's something I can keep my eyes on.....
imboden
May 16, 2015 05:43 AM
aclass
Jan 18, 2012 08:37 PM
ironfist_001
Mar 30, 2010 10:39 AM
rodehard
Aug 14, 2008 12:26 PM
schumacher
Jun 3, 2008 09:21 PM
