leff turn signal will not flash
Old Aug 13, 2018 | 10:25 AM
stylz1's Avatar
stylz1
6th Gear
Default leff turn signal will not flash
signals light up, the right works fine, but the left will not flash.? the right one acts a little wierd but works?
Old Aug 13, 2018 | 10:40 AM
Decker72's Avatar
Decker72
Cool story.
Have you checked the bulbs?
Old Aug 13, 2018 | 12:01 PM
nevil's Avatar
nevil
Welcome to the site.
At the minimum, the year and model would be helpful.
Old Aug 13, 2018 | 12:12 PM
WhiteNoise's Avatar
WhiteNoise
I'd just check the bulb. One of the filaments might be busted.
Old Aug 13, 2018 | 12:40 PM
Felix 808's Avatar
Felix 808
If that does not turn out to be the problem check your grounds especially if you have changed your light fixtures. Had this happen on my custom dynamics turn signals. They came with the grounds paired incorrectlly on one of the lights, runing ground switched with blinker ground.
Old Aug 13, 2018 | 02:02 PM
stylz1's Avatar
stylz1
6th Gear
2005 Road King Police
Old Aug 13, 2018 | 07:54 PM
Bone Doc's Avatar
Bone Doc
Welcome to the forum from central Texas
Peruse the forum. There are forums for each line of bikes; Softails, Dynas, Touring bikes, etc. Yours is a Touring bike but you posted in the Softail forum.
Now, as suggested, swap the left bulb with the right one. If the problem follows the bulb then you need a new bulb. If not then post back and we can offer the next suggestion. You also have to provide details regarding your issues. We aren't looking over your shoulder. When you say the "right one acts a little wierd" what exactly do you mean?
Old Aug 13, 2018 | 08:17 PM
RANGER73's Avatar
RANGER73
I'm confused.
Old Aug 14, 2018 | 06:15 AM
stylz1's Avatar
stylz1
6th Gear
When I turn the ignition on the right signal indicator flashes a couple times and only the right one, all the signals light up but when I hit the left turn signal it will not blink, I switched lamps and still does not work, I'm going to clean the contacts in the socket to see if corrosion may be at fault.
Sandcrab
Mar 29, 2020 12:44 PM
lonerider1960
Electrical/Lighting/Alarm
Aug 7, 2017 04:00 PM
hoethree
Jun 4, 2017 03:08 PM
crabio
Feb 11, 2016 07:39 PM
Primo
Oct 18, 2007 10:07 PM
