I'm planning to replace old bags on my 1999 Fatboy. The new bags are double thick leather that lay over the fender and the thumb screw to fasten the pillion pad seat is way too short now. Do they make longer thread screws for this or should I just go to the hardware store and wing it?
Thanks,
Personally, I'd go to the hardware store and wing it, probably would be a lot cheaper too. There were times in the past when I was changing something on my bike and that's what I did.
If the new bags are going to lay directly on the fender (painted surface) I'd consider a felt pad between the bike and leather to minimize scuffing and wear. That might necessitate a slightly longer screw.
Consider going to a torx safety screw, makes it harder to walk away with the seat.
If you use a Torx, safety or not, and make it a little longer than stock you can add a jamb nut on the underside of the fender. This will also help to keep someone from walking off with your $500 (or more), seat.
