Slim pulls left...
Old Aug 30, 2018 | 04:47 PM
splattttttt's Avatar
splattttttt
Default Slim pulls left...
is this a Slim thing?
Me wife’s cross bones foes strait as an arrow. So its ot a softail thing.
Never really bothered me till now. Been 4 years LOL
I onced checked rear wheel for trueness, and it’s all square. Not sure how well it aligns with the front tho.
Is it a simple fix. And why two very similar bikes be so different in this area?
Old Aug 30, 2018 | 05:16 PM
Axel2485's Avatar
Axel2485
I have a 2017 Slim and have never notice this problem. Of course a single data point one way or the other is hardly a conclusive answer.
Old Aug 30, 2018 | 06:07 PM
jkinner's Avatar
jkinner
If the front and back rims and tires are true I would start with checking the head/neck bearings for wear/loose. Do a Fall away test, My 16 Deluxe was pretty loose, after I had them adjusted it tracked 100% better. Ride safe.
Old Aug 30, 2018 | 07:52 PM
01dyna's Avatar
01dyna
This^^^^ Many years ago I had a 2001 dyna superglide pull left. Finally took it to an indy shop and the neck bearings were loose and they replaced the front wheel bearing. That fixed it.
Old Aug 31, 2018 | 06:04 AM
splattttttt
Riding the wife’s cross bones is such a please. 100% true and no tension or necessary adjustments at the bars.
Mine on the other hand keeps me very busy
Old Aug 31, 2018 | 06:20 AM
Scudda's Avatar
Scudda
My 05 Fatboy developed a pull to the left a few years ago. What I found to be the cause was the right fork pinch bolt was broken, couldn't see it until we really started to dig into the bike as it is under a cover. The right fork walked out a little which made it longer then the left fork, hence the pull left
Old Aug 31, 2018 | 06:42 AM
martin10's Avatar
martin10
Does it pull left enough to feel it? Or does it just veer left if you take your hands off the bars? My 14 would veer left if I took my hands off the bars. I double checked everything as far as alignment, wheel true, steering head bearings and etc. Since I couldn't really feel it when riding I just forgot about it. With the primary and drive belt on the left I think there is a built in tendency for this to happen. If you can feel it pull that's another story.
Old Aug 31, 2018 | 07:08 AM
Jackie Paper's Avatar
Jackie Paper
Put your wallet in the other pocket. The rear is fixed to the frame and so is the engine, so on a Softail, the engine aligns with drive pulley first and secondary within 1/32" the swing arm bushings. The flats at the adjusters are true to the swingarm centerline. So measure from there for alignment.
The front handlebars align the front to rear. Not visa-versa. Her bike tires are probably worn enough that the tires are no longer have an arch but a flat and it has a worn cone shape. Roll a round object and a slightly cone-shaped object on a counter.
Old Aug 31, 2018 | 10:00 AM
uncle kebo's Avatar
uncle kebo
I've had a number of Softails and never had this issue. For friends bikes that have, every time there was something worn or broken..
Old Aug 31, 2018 | 03:00 PM
splattttttt
Well defined questions. My answer s yes ti both.
On the freeway, I add pressyre on the bar to jeep it where I need to go. I can even tell on a traight, that the pressure applied to the bar, put a tilt on the bike even tho I’m ging straight.
My wife’s xbones has new tires front and back and makes agreat bike to add cryise control. Can ride it no hands till it runs out of gas.
fourH-Ds
14
Oct 16, 2024 09:18 AM
Seahorse
Apr 14, 2019 01:16 PM
fafcpa
Aug 12, 2018 10:38 AM
texashillcountry
EVO
74
Jun 12, 2018 06:34 PM
KHauscat
Jun 14, 2017 08:23 PM
