New Deluxe solo rack
Old Sep 11, 2018 | 11:25 PM
PA1195's Avatar
PA1195
Default New Deluxe solo rack
http://www.motherwellproducts.com/se...137-18&Submit=
Got one of these coming later this week for my 2018 Deluxe. Looks better than HD's rack. Will report when I get it on. All I want is a place to put soft luggage which I already have.
Old Sep 11, 2018 | 11:29 PM
iHodor's Avatar
iHodor
They do look nice. You going with black or chrome? I'd guess chrome.
Old Sep 11, 2018 | 11:36 PM
PA1195's Avatar
PA1195
Yes chrome for the Deluxe. The factory part has shown some installation problems here...mine was backordered three time so I will try these. It looks like Motherwell has made the install simple by using both factory seat screws and a single rear screw in the blanked fender hole like the pre-2018 bikes did. We'll see and they are cheaper than HD's plus Made in America. I'm just an owner and not working for them here to sell their products.
Old Sep 12, 2018 | 03:02 PM
68beep's Avatar
68beep
Just put one on my 18 Deluxe; easy install as it goes under the seat so you can take the seat off to adjust suspension without disturbing the rack. Had the HD one and took it off. You will need a fender nut for the rear attach point. Dealers should have them in stock.
Old Sep 12, 2018 | 10:49 PM
PA1195's Avatar
PA1195
Thanks on the info for the installation. I'll check tomorrow about the fender nut from HD. I assumed Motherwell would have supplied one.
Installing a Harley 59768-97 seat nut kit:
We both have the same color. Works for me but I'm not a color perfect guy.
Old Sep 13, 2018 | 07:02 AM
durtyburt's Avatar
durtyburt
The one I installed on my Slim came with the fender seat nut.
Old Sep 13, 2018 | 02:57 PM
PA1195's Avatar
PA1195
I called Motherwell Products and asked if the rear fender hardware (nut and screw) were included. They said yes, but my HD dealer has the nut assembly 59768-97 and slotted 1/4-20 screw. So we'll see in a few hours when it arrives what's in the box.
Old Sep 13, 2018 | 08:48 PM
PA1195's Avatar
PA1195
I received my Motherwell chrome rack MWL-137-18. It looks very well made and came with a bolt fastener, cushioned washer for the bolt, and a foam pad to protect the underlying fender. It did not come with a HD P/N 59768-97 nut assembly noted above and shown in the YouTube installation video. I bought one locally for less than $3 and they're available online. I suspect the rack was designed for the Heritage model which shares the same rear fender but includes a rear pillion seat. With that seat HD installs the fender nut to hold the rear of the seat. On the Deluxe with a solo seat there's only a black plug in the hole.
Edit: The supplied fastener bolt was a 1/4-28 which would take a few years to fit the 1/4-20 59768-97 fender nut HD uses. I'll call them tomorrow and note the discrepancies so they can amend their installation instructions and provide the correct hardware.
big6x6
Apr 6, 2015 09:36 AM
thewholehog
Apr 5, 2015 10:34 PM
220 Dlx
Mar 21, 2011 05:08 PM
ejvette
Jan 17, 2011 06:32 PM
Garett
Mar 12, 2008 11:08 AM
