Instrument cluster dead
Old Sep 23, 2018 | 12:11 PM
Greg Ladewig's Avatar
Greg Ladewig
Stage II
Default Instrument cluster dead
Hey guys. Had to buy a new indicator cluster (comes with the harness also) because two of the LEDs were out. Installed new one, now my Neutral light is always on and the cluster and speedo are blank. Neutral light is on even with the bike off. 2012 FLSTN
Off
On with run on
Old Sep 24, 2018 | 12:54 PM
hattitude's Avatar
hattitude
I hate to be Capt. Obvious, bit if everything worked before your install.... there is a problem with the install.
You either connected something wrong, have the wrong part, or the wrong harness.
I'd recheck the part numbers for proper application/compatibility, and then check your work...
Electrical stuff can be a pain, Good luck with the repair....
Old Sep 25, 2018 | 05:17 PM
Greg Ladewig
Stage II
Checked all that, reinstalled the old harness. Now it has the same problem. Guess I'll head to the stealership next.
Old Sep 26, 2018 | 01:42 AM
j33ptj's Avatar
j33ptj
You may have nicked one (or more) of the wires during the install? if they are grounding then the light will stay on. Or a bent pin in one of the connectors.
Carefully check the harness for damage before getting the dealer involved. It may be relatively simple to resolve
RJ
jeffreydsilver
May 16, 2012 06:11 AM
marinepilot81
May 29, 2009 01:02 AM
joe v
Exhaust System Topics
Sep 23, 2006 05:03 PM
batorizer
Jul 27, 2006 06:54 PM
ranger32@comcast.net
May 28, 2006 10:37 PM
